Headlight ?'s
I just install the 9011 HIR bulbs in both low and high beams. There is a very noticeable difference over stock bulbs. Me likee.
I bought some strong LED bulbs a while back, and they definitely have some spread. No doubt about that, but they are so incredibly bright. I have them for the lows and highs, and the high beams are about as bright as my led light bar is. The spread isn't too bad though. After playing with them, they are pretty steady ahead of me without being too much off on the sides or up.
I am all for depo with retrofit. $300 for depos, $150 for morimoto mini d2s and shrouds, $45 for DDM tuning hids, use or build a hid/hi lo harness or mod a slee harness to work $30. Misc bits and pieces along the way but nothing too spendy.
Order everything, get it all in, remove metal clips around the glass, throw the lights in the oven when the wife isn't looking for 15min, pry them open, bolt in the projector, install and aim projectors, remove and finalize the fitment, throw glass back on and in the oven, remove and throw clips back on and ready install. That's pretty much it in a nut shell. Total time is maybe 2-3 hours if you work slow. There is no cutting/grinding or fabricating anything. It's the most expensive but by far the most rewarding option in terms of headlights.
I myself run depo lights with FXR projectors, 55w ddm hid, custom harness and rigid dually pods in the fog light/high beam position and xb rgb halos.
What is the difference between the HIR 9011 and John Deere bulbs?
The JD bulbs last a long time. They lasted 5 years. Not sure of the moisture from the crack in both headlights contributed to the bulb going out or if they just died.
If you are buying a 9011 bulb, you are buying a Philips of Germany manufactured bulb. From what I've seen they are the only game in town when it comes to the 9011, regardless of what package might say, Wagner, JD, etc.
I bought the 9011's on Amazon and they are definitely brighter than OEM bulbs. My question is this, there's two Phillips 9011 bulbs listed on Amazon, a 9011 and a 9011C1. The 9011C1 is listed as being 65W, and some of the reviews says it's a true HIR bulb, leaving me to believe that the other one isn't. I have the 9011's and now I'm wondering if I purchased the wrong ones.
Amazon.com: Philips 9011 HIR Standard Halogen Headlight Bulb (Pack of 1): Automotive
http://www.amazon.com/Philips-9011C1-Light-Bulb/dp/B007XMLPTI/?tag=ihco-20
And to add to the confusion, they also have these. I ordered some last night.
Amazon.com: Wagner Lighting 9011 Halogen Capsule - Box of 1: Automotive
I initially upgraded to the HIR 9011 and 9012 but ultimately went with the LED's for Lo and Hi. The LEDs are much brighter. Definitely more spread, but I've never been flashed by oncoming traffic. I also like that the LEDs run cooler and have cooling fans. I run them constantly even during the day.
How weather proof are the cooling fans? I considered going that direction at one point just because. However the cooling fan thing scared me away. I don't going looking for water crossings that deep... But you never know what the trail may deal you.
The rating is Water-proof IP65. So for most driving conditions they should be good, but maybe not ideal for total immersion.
... I also like that the LEDs run cooler and have cooling fans. ...
Could just water cool them? :idea:
'Lifetime LED' @ southeastoverland.com*, those bulbs are an option worth considering...
Big improvement over stock or HIR, its fairly close to HID performance but with less cost & hassle than an HID retrofit
*You might be able to find them cheaper elsewhere, but they had the best deal going back when I got mine*
Hi all, first of all I am originally from Connecticut and moved to Alaska years ago were it gets fogy and snow. Driving in those conditions at night it is best to put the low beams on, you can see better. So with these high power nuclear out put head lights I was wondering how this effects your driving ability and eye strain at night time while driving in fog and snowy conditions. I want to get some of those high out put lights but do not want to end up in the ditch. Comments please.
Don't forget the slee harness. Cheap upgrade and although I have never installed one, I have owned trucks with and without them, and the ones with them have much better headlights (just using whatever bulb is available at the parts store).
After installing the Slee harness, I noticed some change in brightness, but not enough to recommend purchasing. About a 10% increase
The First John Deere bulb I bought was a GE bulb (if I remember correctly). Later I bought a set and it was made by Toshiba. Who make them now?
For cold weather you need a bulb that produces heat or they will melt snow or ice.
My two cents; do not install lamps that are super-xenon-blue-mega-Ultra-I-want-everyone-to-think-I'm-cool-bright. IMHO those headlamps are dangerous (to oncoming traffic) but also illegal in most states. Talked to a Deputy Sheriff recently who wrote a ticket for someone who had just spent $1000 on new headlights that were illegal (brightness and color temp too high). The Sheriff said he would not allow the kid to drive the vehicle home, kid had to have his vehicle towed home and then remove the illegal headlights before it would be roadworthy. FWIW.
My vote is for the Candlepower lamps, brighter than stock but they won't blind drivers on the road.
My halogens are not as "bright" as most HID and LED lights but the high beams project further than any aftermarket headlight I have found. MY headlights project about 30% farther than my LED light bar. LED low beams have a great spread but I too would worry about fog, the right lenses would probably make the difference. "bright" does not always translate as "better".
I wish we had some officers like that around here tbh. A guy I work with has them in his truck. Just being behind me in my car leaving work about blinds me:bang:
