Its against the law in my state to bill more than 10% without notification.
Yes, same here, and in our shop I would call the customer to talk it over. I don't want to discuss that issue here. All I want to point out is that there are two sides to the story.
What I want to point out is that you catch more flies with honey than vinegar. Discuss the concerns with the shop. And BOTH sides should ask more questions. If you call a machine shop and as for a head surfacing and valve adjust on a Toyota inline 6 head, they might have assumed an older style head with adjustments that can be made. Yes, bad on their part. Then you drop off a 24 valve head with buckets and shims and the ball game changes.
A head rebuild quote is not the same as a 1FZ-FE head rebuild quote. If he just quoted a generic head rebuild without knowing what it was, I could certainly see this happening, although he should have called to clarify. My machine shop did when he saw "the biggest 4 valve aluminum head I've ever seen"
Yes, that is my point so that people that read this can get some info out of this vs. just a pissing match about pricing. Explain what you have, explain what you want and make sure you know what you are explaining. You are assuming the shop is a professional shop, and they probably are, with anything than a 1FZ. Make sure the shops knows they are going to be dealing with something unusual. If they then tell you, head we are pro's and we know what we are dealing with, and it comes in different, then they have to suck it up.
A full valve adjustment is in no way the same as a valve grind. A valve grind does not equal valve stem guide replacement either. They are different jobs. All of these jobs is especially difficult on a 1FZ head. Twice as many valves and bucket and shim adjusters that require installation and removal of the cams, sometimes multiple times. Also if you don't have the assortment of Toyota shims on hand you have to order them. Not all of them are available. I had to make some on the last 1FZ head I did. Nothing is easy.
Exactly. That is why it is important for customers to know what they are asking the shop to do. And also why it is important to know how to compare apples to apples.
The quote listed above is a quote for valve adjust. Which means, read the caps, replace / swap shims if needed. Valve job is really vague. Does that include lapping the valves, grinding valve seats & valves, install new valve stem seals? If you took that quote and you assumed that all the above is included and you got it back and it was not done, how would you argue that?
If you kept calling and giving him additional instructions, I could easily see him just saying OK and adding to the bill. That would qualify as approving additional work.
Tipping the valve stems is part of a valve grind.
Yes, that is what I am trying to say as well. You call and ask for a head inspection and cleaning / surfacing. Again, these situations are due to bad communications on both parts.
