Head Removal (71F)
okay I found out yesterday from Cdan that toyota no longer carry valve regrind kits. I can get an OEM head gasket from him but I wanted to get a majority rule vote.
1. Purchase the OEM head gasket plus an aftermarket regrind kit.
2. Purchase man-a-fre valve regrind kit.
3. Purchase CCOT kit.
Get the OEM headgasket and if you can manifold gasket. I don't care what else.
X2 on the headgasket, but I have had good luck with a FelPro manifold gasket.....even with a header.
JMO
Ed:beer:
JMO
Ed:beer:
Cheapass header
Sure thing!!!
TOYOTA head and manifold gasket it is.......
so no one has used ccot or man a fre's kit ....
Not mentioned much when I was doing my research, just felpro and oem talk mostly.....
Yuh-huh! :D
The Glyptal in the rod/lifter recess looks nice but the top of the block looks like hell. Is that rust all around #1 only from the gasket leaking? Got any pics of the combustion chamber? If it's been leaking in there a long time, it could explain the knocking, since the lube gets washed off the cylinder wall and you end up with excessive wear & piston slap. I know it's an F head but you better look it over good for cracks. By the way, was that sumbitch heavy!!?? Wait until you re-install, when the slightest slip will destroy the gasket, then it gets real heavy!!!
I'm going to clean the block tomorrow morning, I was getting crap all over the place with the scaper I was using so I stop to cover up some. Rust??? I don't think it's to much but i'm no expert. There sure it a lot of crap from the gasket still on there thou. I snap a shot with I'm done.
Here's a closer shot I took.
http://i12.photobucket.com/albums/a202/m1n166/IMG_9176.jpg
Nice comment about my back pain....
More work
I see you already got a 1mm overiszed piston in there. The area where the piston is pretty much spotless is where the coolant was leaking. It is not that much more work to drop the pan and push the piston out, so I recommend doing it so you can inspect that cylinder & piston, including measuring for out of round & brush honing. I couldn't make out any severe scoring because of the angle but sometimes you get piston skirt problems, like scoring or cracks, that you can't see until it's outta the block.
Okay, two weeks has past and just the morning I received news from the shop that my head is cracked. Bad NEW for me, I don't know how that would have happen considering my rig doesn't get used very often(although that would explain why I overheated when driving to marksoffroad shop). I plan to make it my DD but now I have to find a replacement head. I'm going to get a second opinion from another shop but I'm sure I get the same answer "cracked". I've got a lead on a 74 complete motor but don't have a cherry picker to rip out my motor and put in the 74 motor. I was thinking prehaps to swap the heads, what do you think about that ? "WHAT A BUMMER, I can't wait to get my rig on the road."
I don't know to much about the 74 motor other then it was rebuilt a year ago and it is sitting on the floor of this guys garage because he did a v-8 conversion. I was thinking I can't go bad with a deal like 50bucks for the whole motor.
50 bucks! better hurry, or you'll have some competition from someone in Arizona!
Also, someone correct me if I'm wrong. That 74 engine should be a 2f......
You're looking at much better oil circulation. If thats the case I'd swap units.
P.s. cherry pickers are a common item at the local rental shops. Thats where I go when I need one.
75 2f
A 74 1F also has the upgraded oiling system, same as a 2F.
The F in my '71 lasted 29 years and I replaced with a 2F. That being said, for $50 I would gladly put a rebuilt F back in if needed for that price, new oil system or not, and be happy if I only got 10 years out of it...
Fifty bucks sounds like a heck of a deal...........if you have a place to store it, and the time to install it.
Look at your track record, think of what other 'discoveries' you could find during the course of pulling your old trans, transfer, clutch etc out of the truck, and then try and do an ETA on when the rig might make it back to the road.:frown:
Here's another option. Buy the valve regrind set and valve cover parts from me and I'll GIVE you a cylinder head! :bounce:
This head came off a good running 72 engine that was donated by fellow MUDer John Ermakovich with the intention that I pass it along to someone else in the community. The engine sat outside the shop for awhile, nothing came up, I sent a few of the rocker pieces to Poser, and finally dismantled the engine. THe pistons and block were perfect, but there was no home.:frown: It went to the dump.
LMK
Mark A.
That sounds like a good deal mark and I would be all for it but the situation is, I bought everything I needed for the job from Cdan and a 2f valve cover from a fellow mud member. I'd be interested though, let me know so I cound work out a road down there or get my little bug ready for the drive. I'll be buying the 74 motor as well, I just need to rent a cheery picker or I could man handle it and get a hernia(more like a smashed foot or two). Perhaps I could be able to borrow the guys cheery picker that i'm buying the motor from, I'd just have to do two around trips. I'll be calling the guy up today about the motor.
Oh yeah, thanks for the support cause it's much need right about now.........
