Head Removal (71F)
Maricopa, AZ
Hello everyone,
Current situation : :doh:
valve problem switch lead me to notice a knocking in the block. I've concluded that it's the number one cylinder but regardless, I'm going to take the head and oil pan off to inspect it thoroughly. I hope to find the problem and possibly fix it with the motor in vehicle. I know it's not the best way but this guy is always on a budget. Nevertheless, my budget is for saving up money to spend on my rig(lol, the irony).I'll be able to post pictures up when it's all apart for some expert advice. Plus everyone loves some Cruiser porn!
Gaskets :
Past experience with other motor I've found it benificial to order an overhaul gasket set and plan on doing this.
Looking at many forums for about a week now, I know that people have there person perference between OEM and Felpro. Consquently, there is no comments about Man-A-Fre or CCOT gasket kits. Why is that??? Does everyone buy individual gaskets cause I find this method to be a PITA:mad:. That's why I plan on order a gasket set. I want to order the manafre overhaul kit.
Shop:
I'm currently looking for a shop around the san bernardino area to possible mil down the head. I read a thread about upgrades and this was one performance upgrade I could do well the head it out. I can't find that same thread and I'm just burning time as I look for it. I believe it was Mark W. who had a reply posted to the performance upgrade and said mill down the head but not sure how much. From my memory I thought it was .06-.08 and I would like to know what to measure to see if the head as been mill'd before or not. Just to know how much room I have to play with. I would want to have it milled down if it doesn't have the room for it.
What to watch out for...?
I have the 71-74engine fsm to help me throught this process. I've done a head removal before but never on a Land Cruiser. With that said, please let me know what to watch for so I can avoid common mistakes and get this done right the first time.
ALL advice and recommendation would be greatly appreciated!!!
Thank you in advance..... :cheers: Happy Holiday's
P.S. Didn't me to write so much but I'm heading out right now and won't be online until tomorrow so I wanted to put it all out there
Order a valve regrind kit from toyota. It will have what you're looking for. Many recent discussions about head gasket failures from non-Toyota replacements.
Cruiserdan here on Mud (He's American Toyota under "support our advertising vendors") could fix u up.
That's sounds great!!!
How do I get in contact with Cdan???
I've seen his name mentioned plenty of time on this forum but never really seen his post. Thank for the info. seems like the only bite that i'm getting. LOL
Top right hand corner of every page on Mud: "support our advertising vendors"
link. Hit it, and you'll get the advert for American Toyota with his number on it. He is extention 8. Mention IH8Mud when you talk to him!
assembly
Okay I upcaped the head last night.
I would need to remove the two studs along the rod to remove the assembly and then the head bolts removed in sequence. correct.
Consider it done, Thanks again IDave....
You'll have to remove the stud nuts/bolts and the oil tube that comes up in the middle of the rocker assembly, then take off the rocker assembly. Then the head bolts.
Don't forget the head bolt #1 in the middle (ask me how I know you can)
update
Can you see where the stud came out, plus I figured since there wasn't proper torque that why the gasket was cracked too.
last night on got everything off and ready to pull when I get the next chance to pry it off and hopefully man handle the head myself. It would be nice to have a second pair of hands but that never seems to happen in my case. One man crew!!!LOL
REGRIND kit ordered...Cdan
2f valve cover bought......felix
D-shaft shipping soon compliments to JuttyShabango
You should be able to man-handle it yourself...it will be heavy, but if you stand up on the fender/battery tray, you should be able to lift straight up. Remember....lift straight up until the bottom of the head clears the oil tube....when I took mine off, I pulled up (just not far enough) and then out. When it wouldn't come all the way out, I couldn't figure out why...then I realized it was the copper oil tube stuck inside the head :doh: fortunately, copper bends and it didn't do any damage.
Best of luck in the rebuild and just remember to keep all of the pins for the oil tubing/rocker assembly together. Makes it easier. Also, I've heard that the lifter rods should stay in order as well. Not sure if its true or not, but it doesn't take too much time to number them when you pull them out.
x2 on the oil tubing. I've screwed one up accidentally just that way.
Watch the copper tube on installation. I somehow kinked mine and burnt up several new exhaust valves. May want to take off the side plate and install the tube after the head is in place. Also double check the oil flow on the rockers before putting on the valve cover.
I'm glad to know that I wasn't the only dumb*** that made that mistake :grinpimp:
As far as checking the oil flow to the rockers, I did the same and risked it with the engine running. If you want to do it without the engine running, I've heard a good way to do it is to pull the dizzy and rig a screwdriver drill bit to fit in the bottom of the dizzy (oil pump) and squeeze the trigger clockwise. This will in effect pump oil up the tub and to the rockers. You should see the oil start to come out of the little weep holes on the rockers. Just make sure that you're dizzy gets back down into the oil pump when you re-install.
Good luck :)
I strongly recommend it. Copper tube is now obsolete.:frown:
What's risky about it? The oil barely drips out anyway.
I'm not sure what it'll mess up running the engine for several minutes with no oil to the rockers, but usually its best to be safe than sorry----advice I give but don't always live by :)
I figure that if the rockers didn't need oil, they wouldn't have messed with some stupid copper tube that is always getting in the way.
Mark, I might actually have a spare copper tube out of my old F. I'll have to check. Is it worth the effort to pull it off?
Okay,
I figured I would be able to get-her-done before work but that's not the case. I gave a couple nice hits with the brass hammer and towered on top of her to man handle the head but no movement at all. Could there be a sealant glue that's kicking my ass??? I'll give it another try later today after work, just wonder if anyone else has encountered this. I remember with my transfer case, the pry bar did the trick but not in this case.
Thanks for all the advice so far......
I'll definately remove the side cover and copper tube when i get back home.
A thin blade putty knife tapped carefully around the edge might just break the seal for you (try not to mar the surfaces). Be sure you got all of the head bolts out. Number 1 is easy to forget!
Much thanks, for all the tips guys.
everything you guys mention was done and greatly appreciated.
I never thought I was going to get the head off so I use the putty knife trick and presstoe. I would have never thought of that.
Does this look like an OEM gasket to you guys, of course, mine is traveling in the mail from cdan so I can't compare yet.
Would a crack like this cause a big enough vacuum leak for my rig to backfire through the carb.
http://i12.photobucket.com/albums/a202/m1n166/IMG_9161.jpg
any recommendation for my valves. here's a big question from my first post, how can i determine if my head has been milled down and now how much should I mill down for performance. I've read from a post by mark to ( .07-.10), I would love to do this for my rig but need to know how to determine how much to mill. I know from the .040 stamps on the piston were worked.
http://i12.photobucket.com/albums/a202/m1n166/IMG_9163.jpg
http://i12.photobucket.com/albums/a202/m1n166/IMG_9176.jpg
Now for my 2f valve cover: from other threads I've read I would need the studs and cap nuts for the cover to seal properly, right. Perhaps I could there is another way......
http://i12.photobucket.com/albums/a202/m1n166/IMG_9178.jpg
I have to agree with you , this site KicK's A@%...
