I have 14 used bolts from my HG jobber. PM me and we can work out where to send a few.
Good stuff, thanks for posting that! The 'Birfmark' PDF version I have doesn't show this diagram...at least not in sections EM or SS.My version of the FSM states where to inspect the bolts... a little late but maybe good for someone else.
Eric
Just wanted to follow-up on the retorquing of ARP studs. I asked the techs at ARP and this is the email reply I received this morning:Have to pull the cams too. Not terrible but yes a one time job.
From ARP's tech:
"Yes it's recommended that you re-torque after it's been run up to
operating temp and let cool completely down. Then check again after a few weeks"
RonF
The torque is going to be specific to the studs that you buy and the material they are made in. I beleive the 2JZ studs work, and the L19 studs are torqued to 35, 70, 105lbs.
Re-torque is dependent on the head gasket manufacturers recommendation, as with re-torquing you are trying to compensate for the gaskets initial compensation. It would be recommended to follow what the gasket manufacturer says.
Regards,
Zac Kimball
Automotive Racing Products
(805) 339-2200 ext. 206
Compensate for the gaskets initial compensation? I'm not sure what that means. Is he talking about some kind of compressing of the gasket due to the clamping force.
You'll notice I didn't say the re-torque was dependant on the studs, I said the torque was dependent on the studs. Stonger material requires higher torque specs.
The retorque is based off of compression of the head gasket like the ARP tech says. If you are using a metal headgasket that doesn't compress but very minutely than I would say no retorque, I would retorque a stock gasket. But I would have used the stock headstuds too.
