I about to see install the HG tomorrow. Just a few questions. Cleaned the block surface really well with a razor and schotch bright pad and shop vac. I figure right before placing the HG I will wipe down head and block with brake clean. Also I cleaned all the head bolt holes out. Figure will use just a little assembly lube on bolt threads and the washers under the head bolts.
Also the fsm calls fr some adhesive under hg in two spots near front timing chain cover. I was gong to use a SMALL amount of FIPG. Just on the two areas shown in fsm. Does this all sound good or am I doing anything wrong?
