Head gasket - is this correct?
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
Before buttoning this up I want to be sure this is how it should look.
I’m surprised nobody has said, but yes - dead money!
You nailed it.
I love how well indexed the 1FZ is.
Spray it all down with brake cleaner to make sure theres no oil or lubrication on anything like the chain or gears or cams. Those parts like rawdogging it on first start up.
Note: i am being sarcastic. Do the opposite of my suggestion
First time doing a headgasket, just wanted to be sure, thanks everyone for validating my settings.
You cut that zip-tie off the timing chain sprocket yet ?
Yes, ever so carefully. I put a rag around the whole assembly before cutting it for fear of a piece of it dropping down to the netherlands.
The only thing I recommend is smearing the bearing journals with assembly lube before you tighten everything. Same with the cam lobes.
I've not been in my 1FZ yet (knock on wood) but every other engine I've done top end work on I've used moly assembly lube, they are still running.
Turned it over for the first time. Let it run for a few seconds then turned it off and repeated that four or five times. Let it sit for a little bit so that oil could flow.
No check engine lights. No codes. But after letting it run for about one minute or so it only achieved about 300 or 400 RPM. Is that normal?
Sometimes after an ECU reset (disconnected battery) the idle speed can be weird. Did you try and rev it up any?
Won’t go above 450rpm
To confirm - it won't go above 450rpm no matter the throttle position? Can you confirm the throttle cable is attached correctly and the throttle plate is moving?
The video may be the wrong one, looks pre new headgasket to me.
