I have a '93 FZJ-80 with 196,000 on the clock. I purchased it a little over a year ago with little PM documentation. I immediately started baselining the truck and sent a sample to blackstone for analysis which showed some coolant in the oil. I then completed a compression test which showed excellent results (190-196) across all cylinders and a block test (actually like 3 or 4) wich was negative. At that time I changed the oil, drove about 1000 miles and sent another sample to blackstone. The results did show trace amounts of coolant but it was such a small amount they asked if I had done the head gasket. At this point I felt like everything looked pretty good; so I figured I would keep driving and monitor the coolant level and oil. I also did the temp gauge mod (Raventail?) just for good measure.
Fast forward about 6 months and I have only put about 3500 miles on the truck and it sat for several months while I was away for work. Since I want the truck to be as reliable as possible (my wife says I'm looking for something to fix) I decided to do a leak down test as a final test to rule out a HG failure. Cylinder #6 showed minimal leakage, less than 5% at about 75 PSI. There was no noticeable air coming from exhaust, throttle body, or crankcase. I did not see any "bubbles" in radiator BUT after about 10-15 seconds the level slowly rose and started spilling over some. At this point I assumed HG failure and started packing it up. However I decided to go ahead and check cylinder 5; it showed slightly more leakage but still less than 8-10% but no bubbles. The engine had cooled a bit by this time so that may have been the reason for slightly more "leakage". Also, I used a vacuum gauge to find TDC.
So today I took another oil sample which will be sent out tomorrow and decided to do 1 last block test. I used a spill proof funnel and allowed the truck to get to operating temp, and cracked the throttle to maintain 2000 RPM. I cut both ends out of a water bottle and inserted one end into the funnel and used the other end to insert the block tester and draw air through without pulling in coolant. I tested it at 2000 RPM for about 10 min and did not get any color change. There were a few small bubbles that came out, and I made sure to get the air from those bubbles pulled through the tester... No change. Just to check the fluid I then took it to my exhaust and within seconds the color changed to yellow.
So to sum things up....
- Truck runs great. No issues at start-up, idles good, no hesitation or stumbling.
- No visual mixing of oil and coolant. Coolant is clear (green) and oil looks like dark honey. No milk.
- No overheating, and no real coolant consumption.
- Good compression across the board, #5, 6 are both 194
- Multiple block tests performed with no color change to test fluid
- Leak down test did allow air to enter coolant on the #6 cylinder
- Spark plugs are clean, but not steamed. #6 has some white/ reddish crust but nothing major
The engine appears strong and I am going to continue to monitor and drive while I await the results from blackstone. Any idea how air can find its way from cylinder to coolant system and not show on the block tester?
