In the process if hunting down a wobble I checked my wheel bearings to see if they were loose. Sure enough both sides were loose not terrible like with oem spindle nut set-up but the concerning part is the set screws had made contact with the drive flange for many miles and the Allen head was gone from making contact. New keep in mind these screws were still very tight. I know these were made for minis but I know several are using them in 80s. Did I do something wrong when seeing them up? Original bearings as far as I know. Can't seem to figure out why they got loose again. Has opened up the front after installing trail gear spindle nut and finding similar issues? At the nlxacty point here
) it has been recommended to use pan head screws to get the needed clearance with drive plates.
