I'm a total noobie, and a bit overwhelmed by the amount of information I should know and that is available here before I buy my first FJ40. I feel almost stupid posting some of the questions, because they are so basic ... yet I am struggling to search for the answers.
1) How does a hardtop attach to the tub? I assume it's bolted down. If so, how many bolts, and are they easy to get to? I am sure there are pics on here that show how that happens, could someone post a link to a post where it shows it?
2) If I buy a FJ40 with a softtop only, can I easily buy a hardtop to replace the softtop for the winter?
3) I read a thread on here about the hardtop having rubber seals, and that maybe removing it is a bad idea because it makes the seals not function as well? Is that a normal stance or was that just because the hardtop was original and never removed before (and thus the seals were original and possibly brittle)?
4) Is the hardtop easily removed for a weekend, or is it a lot of work to remove and replace the hardtop?
5) Has someone posted a overhead garage wench type set-up to lift and hold a hardtop overhead while not in use?
6) It seems that F2 engines are more desirable than F(1?) engines (is it called an F1 or just F?). Can someone point me to a thread where they discuss the differences and the downside to having a non-F2 engine.
7) I like the idea of having a farmer jack installed on the FJ40. I have seen several pictures here with them. How do those get mounted? Any detailed pics with those mounts?
8) What would a typical setup look like where you have both a spare tire and spare gas can on the rear? Is it either/or or can you have both?
Well ... that's enough questions for now, but I sure have plenty more.
Thanks in advance!
Thanks in advance!
