Hardtop pop rivet help?
Use at least 3/16" rivets. The topper for mine blew off in a wind storm, and has required extensive repair. Get longer rivets so you can use washers. I might even attach screws and nuts in a few spots. I don't want it to happen again.
I used stainless pan head screws and stainless nylock nuts in place of the rivets (nylock nuts on the bottom).
You'll notice it at first, but after a while you don't even notice the difference. Another upside is that if you do need to pull the fiberglass portion off for any reason you just undo the screws and take it off.
That's my two Abe Lincolns
Question................I have never heard of one needing repair, blown off or coming apart.
Did you loose the rivets? Can you loose them?
CCOT sells a kits I thought
I made a set of tools to pean over the shank of a Buckhorn rivit, by heating ( red hot )the end of a 10mm bright shaft and driving a 6mm ballbearing half way into the end. this give's you the nice round looking head on both ends of the rivit, when used.
How about a pic of that tool? It will be a while but this is a job facing me...
all you have to do is flop it over. it'll need repair. trust me :D
Kind of a tuff way to test your top!!!! Great picture though!
Old guy I will PM
The story is, when I bought it several years back it came with the top minus the fiberglass cap. A few years back I came across the cap and it has been sitting since so I thought it might be time to finally put it together.
Thanks for the INFO evryone!!!!
Go to your local HWI hardware store and pick up a box of 100 pop rivets and a gun, get at least 3/8" so you can use the washers. Use steel, not aluminum, and go longer if necessary cuz you can grind the excess off with a dremel. Worked for mine. Then use automotive sealer to get it all nice and weatherproof. Cheers!
I wasnt sure what the originals looked like. My first FJ (72' that I sure do miss) had a soft top. My project (70') had the sides with no cap and half a rain gutter with no rivets in either of them. So buckhorns it is. I must have looked at CCOT a million times (thanks Dusty 66)and never noticed the rivets, go figure? Interesting tool Oldblue might give it a shot.
Once again thanks to everyone for the advice!!!!!
