Dissent, are you sure about the bolt threads? I would have thought the Cruiser would have a metric bolt. I am looking for a eye loop bolt or eye nut. The eye nuts are approximately $7 to $8 a piece at McMaster Carr.
It's 7/16-20. Dissent is correct.
I confirmed the seat belt bolt size of 7/16x20 and ordered a couple of these.
http://www.mcmaster.com/#3014t941/=wsq6qq
The description on Amazon looks wrong, because they call them 5/8" rings. I figured I'd buy one based on Dissent's post (and it being the same part number retrofive located on the RaceQuip site. It turns out the Amazon link is a usable part. The hole in the ring is 5/8", but the threaded bolt is 7/16"x20 (as Dissent said and others confirmed is the correct bolt pattern for the seat belts). As shown in Dissent's pictures, the eye fits a climbing carabiner.Amazon carries the RaceQuip eye bolts in long and short versions. Enjoy!
Long - http://www.amazon.com/RaceQuip-700060-Diameter-Long-Hardware/dp/B004QMFK3A/?tag=ihco-20
Short - http://www.amazon.com/RaceQuip-700050-Diameter-Mount-Hardware/dp/B004QMJ85Q/?tag=ihco-20
Perhaps I should check the local speed shop for pricing. Two for the price sounds better than "each". I think I'm going to get carried away with these rings. I plan to replace the top bolt from the 3rd row seats with the short rings. I cut a hole through the plastic panel in back to replace the bolt that held in the rear seat belt retractor. I may do the same with the second seat seatbelts, except keeping the seatbelts and retractors, and just using these rings in place of the factory bolts.I ordered one through amazon myself matching that description. Only problem is they are priced each whereas the ones from the local speed shop came in pairs.
