No not engine related
@Fj moneypit got it!!! Dindingding
It was the left front hub. And yes I use a BFH lol ... however I blame my father
... he was born with one and his father before him lol
Sooo I was driving and slowly over the past few months I had a low speed shimmy from the left front tire ... thinking it was just a balance thing I ignored it
It would go away after 10 mph span at about 30-40
I run a single counter weight to the ring split on my rims but also use internal weight to balance
I eventually checked and weight was still there hmmm
Ok must be condensation built up and not dissipated from balance beads in tire ... but... went on a long LONG Ride to Maine
Shimmy still there ... wth
Then it seemed to get worse and in the infinite wisdom I thought I should tear into it ... finally
Pulled the warn hub off ... could not find the c clip spreader ... man what a pita without that
So the axle nut had backed out because there were no lock tabs holding it
the lock washer was kinda flopping between the outer axle nut and inner nut
The inner nut however was still tight ... however loose enough to feel play when I lifted the front tire to check the wheel bearing ... if I didn’t feel play I may have been that stupid to leave it thinking it wasn’t the issue
Thank God I checked and there was play
The bad news is the ring is only holding on by one tab to the nut now
Q: how many tabs on the star washer do most people have locked on the nut? 2? As many as possible?
Q: Are all the warn hubs do they use same kit to rebuild?
Q: what size is that nut ? I’d like to get a socket as to not ruin (yes they are screwdriver set in the past) the nuts as they are in great shape
