GX470 - premium fuel??
85 is a bit lower than recommended, but the altitude plays a part in that calculation too.
You will be hard pressed to find 87 or 93 at altitude.
Altitude plays a big roll in the ratings, since you vehicle get less air it needs less octane.
There will be no problems with lower ratings up here.
I really just want to say that there's literally no point in not putting in premium fuel if the manufacturer recommends it. It's what the car is designed for, and the extra cost per tank is minimal. If you're going to buy a nice car, don't cheap out on it. :)
I have never hear a knock or felt a lost in power or stepping of power the times I have used reg.
I have recorded my best 2 MPG using reg fuel 22 and 21.5, my best on premium is 20.
right now I am on empty and getting ready for a trip to Chicago, so I will do a fuel tank of Premium and see how the GX does, plus I am pulling my little off road trailer.
Lexus very well might have a different tune, or ECU set up for the GX, but there are many who run reg fuel and have not had a problem, heck who knows what was put into our vehicles before we got them. Todays ECU should be able to adapt timing in a nano second and I think should be OK, unless you get some really bad gas. I use "Top Tier" when ever I can.
The higher the octane the slower it burns. As a result, the ECU can advance timing which will create more power. Now keep in mind, the advancement or retardation of timing isn't infinite, as it's only able to advance or retard in relation to its programming. So even though your very minor lower fuel economy differences could technically be attributed to premium fuel because you're creating more power, there's many other factors that can also be attributed to those numbers. Detonation occurs when you're creating uncotrolled fuel ignition before the combustion stroke, typically as the piston is traveling downwards. A benefit of premium fuel in vehicles that either require it or don't, is it typically contains more detergents. Detergents tend to keep carbon deposits from building on valves and Pistons that are created from incomplete burning. If you have a bunch of carbon buildup, which can accumulate due to poor fuel quality among other things, pre-ignition can occur. It's different from detonation as it generally occurs as the piston is traveling upwards, when carbon deposits remain red hot from the previous combustion stroke and cause the air/fuel mixture to pre-ignite. Pre-ignition is generally much more harmful. Again, Keep in mind the truck doesn't know which of those two things is happening. It just senses abnormal cylinder noise and automatically pulls timing. Hope that makes sense, I'm watching tv as I type this.
Running a tank of mid for SnGs, no difference. Main reason I was running higher octane was for the cleaner burn. Regular with sludge up over time in our lovely motors.
FWIW, I've been running 87 in my 04 since the day I got it and haven't seen any adverse effects over 15k miles. Plus I still average around 18mpg, so I see no reason to change.
Well, that's kind of a moot point since your 04 doesn't have VVTi and was designed to run on regular 87.
Last September when I rebuilt the topend of my 2000 100 series with 190k, I was amazed by how incredibly clean the engine was. The PO always used regular unleaded. Any decent quality gas now has a fair amount of detergents in it, and should not have a huge amount of buildup in a proper running engine. I also did tb,wp, and plugs on my buddies 2004 4.7 4runner with 270k on the original plugs and they still looked great. Borescope showed pretty clean pistons and that was a Midwest truck that gets crappy anything. He uses the cheapest of anything he can find. The 4.7 is an incredible motor. I drive about 3k miles a month and have used premium in a 4.7 exactly zero times. My opinion but it isn't needed unless you're towing or drag racing all the time.
If you regularly run 87, you won't have the stepped performance, or knocking (shouldn't, anyway). The long term adaptives have adjusted the timing lower, so you should be running smooth - but at a cost of less timing, which equates to less power. But if you aren't Autocrossing your GX, you'd probably not notice the difference.....
260 vs 263 for a 06 4Runner vs GX470. 3 hp. You would have a hard time justifying that there is even a difference as engine to engine differences are probably larger then that.
gotta agree
This is from toyota120.com for a 2006 model
4Runner = V8 260HP @ 5400 RPM and 306lb-ft @ 3400 RPM
Lexus GX470 = 263 HP at 5400 RPM and 323 lb-ft at 3400 RPM.
gotta agree
271hp and 313tq for the 06 Tundra that runs on Reg Fuel.
The interesting thing is that the GX does have a decent amount more tq. It is very possible that the TQ increase is due to a Timing bump at that RPM band. So maybe there is something different. I don't know. It's a mess. My 06 Tundra was a TQ'less dog IMHO. Only thing I didn't like about that truck.
looks like compress ratio is the same for the GX470 & 4Runner at 9.6-1
So could it be the head, intake or the exhaust
Seriously doubt this.
Mechanically they're IDENTICAL. It's ECU tuning aggressiveness. Trust me, drive with premium, you will notice the difference.
I have tried to find it but there was a document with posted dyno results for the 2UZ with different fuel direct from Toyota.
I don't notice the difference
