Group Buy: Innovative Wiring turn/marker harness (single function to dual function)
Are installation instructions included with the harnesses?
There are no real instructions with the harness, but there is a writeup on this thread starting on page 15
Works on TJM
I contacted Gary and asked him to make the ARB light portion of the harness a little longer so that I could do the Disco Mod on my truck.
My only concern was that I have a TJM bumper and did not know if the length of the harness would need to be longer..
Anyhow Gary responded immediately and made my harness with the portion going to the ARB/TJM light markers a few inches longer,.. Turns out there was no need, and I just zip tied the extra wire.....The original would have probably fit just fine!
Anyhow great product, great service, works exactly as it should!
And I am happy with my DiscoModded front marker and turn lights! :cheers:
ARB harness.
I am in for one that includes the ARB marker light (triples?). Looking forward to the price on this.
Thanks guys for all the footwork from the start on this. This is a nice mod, just now seeing this post.
KB
I was waiting to hear on this, looking to get the ARB light harness. I hadn't heard anything so looked up the thread. Looks like I didn't make the list for the ARB harness. I posted interest in this, #190 is my post I think.
No worries, I would still like to get one of these with the lights for the ARB bumper included.
Thanks.
Redmon
Thanks.
Redmon
I think they are up on his site??? I haven't looked in a minute. He is good at returning emails either way.
GL
Stu
Sent from my DROID3 using IH8MUD. typos extra
Yes.
GL
Stu
Ahhhh, indeed they are. Last I checked this thread they were notifying via PM. I missed the post with the website but now I see them on line and ordered mine.
Look forward to the install.
Thanks!
Does this harness work with LED bulbs or do you need incandescents?
If you had LED bulbs installed before and they worked with the OEM harness, they should work after the new harness is installed I would think.
If you are planning to install LEDs at the same time as the harness I don't know...I don't have LEDs (except for my back up lights) but I have read where some have issues with the blinker functioning correctly due to the lower draw or something.
Alright guys, I need the brain trust on this. I have all the amber marker and corner lights on BUT when I turn on my emergency switch ONLY the left corner light blinks. When I use the right turn signal, NEITHER blink. When I use the left turn signal then only the corner light blinks. I pulled all the lights and checked them. All good. I'm not getting continuity out of some of the pigtails though. Pretty frustrated at this point.
I'm sure you did but did you verify you have the harness installed correctly and the proper bulbs? You need the 1157s or whatever they are. It almost sounds like you have the left side installed correctly but the wrong bulb in the OEM blinker and that the harness on the right side is installed backwards.
Or, you got bad harnesses.
You mention pigtails? Did you get the ARB version with the extra pigtails?
I just installed mine last night and I seem to have blown the flasher relay? PS went perfect and tested ok. DS installed the same way but now no marker lights turn on and no flash. If I disconnect the DS the PS markers come on but no flash. Any ideas?
What year is your truck?
Did you replace the blown relay?
I am still trying to see if the relay is blown. The PS signal light illumanates but doesn't flash. The hazard/4ways work. And the DS signal light is getting no power when park lights are on, or when the signal is activated. It is getting 12vt when the 4 ways are on though.
Arm chairing it.... but think it is a pin problem.
Has anyone installed using LED bulbs ?
Yes, but you must replace the flasher relay with and electronic one to slow the flash if you run LED all around. Otherwise you get strobe flash ;-)
Matt
