Ordered mine.
thought it was a good modification
Installed mine this evening , as other said the turn signal pins are a bit on the tight side but I was able to get it all done in about an hour . The hardest part was pulling the side marker housing out on the DS as the pin was a little rusty so it didn't want to pull out of the plastic clip .
It now is much easier to see the signals with the ARB on ,but even without the bar in stock form it was poor .
With the disco mod I did some time ago I'm very happy with both![]()
CycloSteve said:I am running standard US-spec amber lamps on my truck, though clears would be nice. Drove it again last night, and just amazed with the amount of light the blinkers give off. I live in the countryside where there are no lights other than you and your rig. You really do not realize how bad the OEM design was until you upgrade.
Steve
I did have an issue installing the new pins into the blinker light plug.![]()
The little plastic 'hooks' of the re-used blinker plug did not want to seat into the recessed portion of the new pin. I shoved the new pins as far into the plug as physically possible, but they wouldn't 'click' in. With a bit of coaxing, more pushing, mangling, I managed to seat them as best as possible and then replaced the white insert to ensure they wouldn't back out. Anyone else have this challenge? Any advice?
FYI, I used a combo of three sizes of cheapo jewelers flat head screwdrivers as terminal pick tools. Work perfectly to remove the pins. The side marker light pin exchange was far easier. Glad this is done. Thanks Ebag333, Otamiway and Gary for making this a reality.![]()
I have gotten some feedback from CycloSteve about his experience installing the harness.
The blinker pins are a tight fit. Once you slide the new terminals into the housing, use a small flat point screwdriver to press down the locking pins.
on my instal, I was a little overzealous removing my pins and had to press them back down. I did not think about it until Steve Pm'd me.
We have contacted Gary to advise him of this.
The press down trick works effort
HTH
Stu![]()
IH8MUD family, gary is ready to develop the ARB Harness and looking for input.
How would like to see the harness developed??
1. Additional pigtail
1a. Marker only
1b. Signal only
2. Disco mod pigtail
Please let me know what you think. I am also looking to hand off the ARB Development since i do not have one as of yet.
Stu![]()
Guys thank for the posts.. Check out post #283 for the tips on the stubborn pins.
I have contacted Gary and he is looking into getting a different pin.
ToyotaDon said:Worked on mine today and found the terminals/pins are definitely a different style. The pics I had posted previously were from an earlier 80-series, and match the marker lights (and what Gary provided). This means you guys with earlier models won't have any trouble.
It looks like the break point for these lights/harnesses is between FJ80 ('91-'92) & FZJ80 ('93-'97). My thought is that Gary may have to offer a couple different options based on year. I am willing to send the 2 different stock harnesses I have to Gary, but I was thinking it might be best to let Stu continue to be the contact person on this.
