IronX and products like Fallout remove help get Iron and other embedded contaminates out of body and wheel paint.
Check some of the links near bottom of OP:
LX470 to build or not to build...
Second to last link is Body trim polishing & correcting compounds. @landylover21 has some great tip on detailing.
I went with micro fiber DA system, which is a bit pricy and not available at HF only online. Cutting pad are different from polishing or waxing's pads. Along with Lacquer thinner & a really good de-waxer & degreaser, which was used a lot by me.
I also like marine grease which I coat rust prone bolt, parts & undercarriage with. It holds on well even when washed with high pressure. Works to prevent rust and helps keep bolts & parts from freezing-up (stuck on do to corrosion).
