Your going to have a very clean rig when you're done. kudos to you for pay attention to detail.OK so I got the metal guard and plastic guard pressure washed today and pressure washed the front under body.
Pretty sure one of my leaks is the power steering unit. I have a lot of seepage through the lines from the resv which is odd.
Yup it was that kind of day.
I did however spend some time tackling cleaning the dash and gauge display and repairing two bulbs. Well one I just re-purposed. Moved the seat belt flashing red bulb over to my cruise indicator. The second was for my "D" light. I know a lot of you mentioned to leave it out as it's bright well I'm to OCD to have it not working so I decided to try a smaller bulb I removed from a "new" old stock Honda dash or switch bulb. It was the last "small" bulb I had in my tool box.
It's PERFECT!
Dimmer than all the others... I decided to do this as those bulbs don't have any colored "condoms" on them. They just shine through the colored lens on the display. The pictures show the difference in size of the bulbs but I'll try and show the difference in brightness somehow.
Also figured out a very easy way to make the felt around the upper column cover look fantastic.
Turn it over! Lol...
You said: "seepage through the lines from the resv which is odd" not odd at all. As you saw in earlier post, this is one of the most common leaks in a 100 series.
I like to pull power steering reservoir off and clean really good. There is a screen at the bottom that sometimes is really hard to get clean, others times not so much. I them re-clamp lines with screw clamps and retighten clamps after each cool down, just a bit more each time until seepages stops. I also flush the power steering with M1 MV ATF after cleaning. It really smooth out the steering pump sounds. I find it best to flush three time, once after each 500 miles or so the first time around.
Keep and eye on the power steering boots now, but don't be to quick to call a leak a bit more at first. As seal get cleaned, they'll sometimes stop leaking. If not, try the seal modifier first, it works wonders.
