Just back from the exhaust shop. They did a great job, exactly what I asked. Owner was a bit peeved at having to re-do his work, but I told him it was wrong the first time... Oh well. It looks great now. I'll shoot some pics soon as I can.
So first big shake down run went well. I am happy with the steering. The brakes need to bed in a little better, but work well. Need some rework on a few things, though.
1. Carb isn't working right. Looks like the accelerator pump is not pumping much. I rebuilt the carb, but maybe the passge is clogged or something.
2. My junk yard steering box is leaking from the output shaft. I don't suppose I can buy a seal kit anywhere
Hate to go buy a rebuilt when every has such a hard time getting a 4 1/4 turn box.
3. TV cable still isn't right, stopped shifting into 4th. Trans leaks from shifter shaft. I have a friend of a friend who builds race engines and trannies. He will do the work for me. At the same time I might have him add in the tc lockup solenoid and wiring for the future. No way I am dropping the tranny again so soon. I decided to keep the lockup tc to use later on. I'd love to wire a lockup switch on the dash so I can lock the tc on downhills. After reading up on the solenoid and wiring it seems a sinch.
4. My new AutoMeter fuel gauge appears to be NFG. When I went to program it the gauge was acting funny and not what the manual said it would do. Now it just moves around from empty to full on its own. I'll give AutoMeter a call since it is brand new.
5. Need to program my speedo.
6. Need to set my brake bias valve.
7. Need to install security screws in the dash so I don't lose $600 in gauges. I have not been able to find the right size security bit so I'm going to grind down a screwdriver bit to fit the screws.
8. Birfs may have damaged my Marlin axle seals because a little oil is leaking from each knuckle. I ran a mile in 2wd with the hubs locked so maybe they will seat better. This can wait because they don't leak too bad.
9. Lower radiator hose leaks at the radiator. New hose and new rediator. Tightening doesn't help. I'll have to pull it back apart.
10. Still need to fab a skid plate.
11. Need to mount my CB.
That is about all I can think of for now.
