In BOLD letters on pages 6-9 and 6-10 of the 1980 FSM, detailing assembly of CV (Birfield) joint: "Coat with molybdenum disulphide lithuium base grease before installing-crushr
ok so when i installed the birf i did coat with grease but i didnt "load" it up 3/4ths full. i was mainly concerned not having enouph grease behind the birf thinking that it could ruin something while driving. i guess ill just get a grease gun and fill er up. thanks everyone for the help. i just hope i put enouph in![]()
Wow - some of the comments in this thread are pretty scary
I've always used Mobil1 synthetic grease, it's a synthetic lithium grease that exceeds the lubrication properties of molybdenum disulfide lithium grease. When you have the birfields apart, spatula in enough grease to fill the bottom of the bell before assembling the cage. If you don't have the birfs apart, the needle method mentioned above will suffice (but you need to make sure any gear oil is removed - will break down grease). Then you need to coat the entire inner cavity of the knuckle before installing and setting the trunions. Once You've installed the wipers and half-moons, you want to spatula in as much grease as you can around the installed birfieds, the manual calls for 3/4 full.
This is where I'm referring to the scary part, where there are certainly differing opinions on this the consensus is filling the knuckle plug puts very little grease in the birfield cavity (bell). What it mainly does is fills the outer knuckle cavity, and when over-pressureized forces grease out your wiper seals.
So, the short of it is you need to pull the spindles and fill the birfield cavity if you want to be sure they are lubricated correctly.
Hope this helps -
Tucker
