grease in knuckle Question
so i just rebuilt my nuckles not to long ago (have yet to drive it since) and i was reading a nuckle rebuild thread not to long ago and it was LOADED with grease and honestly i hardly put any in there, just enouph to lube it up alittle thinking that i could add some more later. theres alittle bolt on the back side to grease it up so i was wondering if i just fill that hole up will the grease reach it to the back/inside of the birf. honestly how much grease do i need in there? any help would be great thanks !
I filled mine to the top, that might not be the right way but I know that a joint full of grease will not let any fluid in. Probably get flamed for sayin that. :meh:
Kept mine pumped full for almost 10 years now.
Not getting it slathered in is just asking for it. Maybe not in 2wd right away, but if you do any at speed 4wd you will likely burn things up. Keep a hand on your hubs and check how hot they get. Will take forever to pump grease into the fill hole unless you have some powered grease gun.
I keep mine full, the knuckle ball joints are very small compared to 80 series. I use Amsoil Seies 2000 synthetic grease.
hmm i think i need to purchase a grease gun then, not sure which one to get cuz most of them have the ones for the nipples but this is just a straight hole, any suggestions?
And another question i had was if i do put more grease in the hole will the grease make it to the back side/inside of the birf? thats what im mainly concerned about.
Thanks!
Filled up and topped off full? I just did mine and filled about 2/3's full, with a good coating on all of the metal. I didn't want grease to get pushed out past the felts or in past the axle seal. Would it help now, to fill them up through the knuckle grease hole?
Gonna work on knuckles soon with a fellow mud'r so it would be good to know.
Thx,
B.
The regular fitting that comes with every grease gun that fits on zerks fits inside the hole of the knuckle just fine.
The only way for grease in the ball joint cavity to get in the birfield is by gravity, so it is not going to get pushed out past the the felts or seals that way. 9 times out of 10, when your knuckle ball is really gooey and dirty, it is because the axle seals are worn and allowing gear oil from the diff to dilute the birfield grease and leak out.
Um yeah, I thought that's what we were talking about in the first place.
As opposed to taking off the spindle and packing it from the front. I had read that filling it from the top wont get grease into the birf .
Did a birf job over the summer when I did my disc conversion. Packed the knuckles full...have driven about 2000 miles since..no problems.. felt still holding up fine..have never used the knuckle grease hole for filling with grease though.
You need to do both; completely pack it when they are apart, and keep grease in the ball-joint reservoir in between teardowns/rebuilds.
When I did my knuckles, after cleaning all the old grease out in the parts washer and blowing it dry, I put the stub axle in a vise and greased the Birf by rotating the inner axle "around the clock" and greased it with a needle tip on my grease gun. I was amazed by how much grease they took. I used the same needle tip to fill the knuckles to about 2/3 full. At that time, I was under the impression that you needed to leave some room for expansion:confused:
Ed
This has been covered many times on MUD. Everyone seems to have an opinion, but I prefer to follow the FSM. Below is from a May thread on the same topic:
"FSM specifies moly grease for CV Joint and knuckle. As does every CV joint vehicle I've ever owned or worked on.
In BOLD letters on pages 6-9 and 6-10 of the 1980 FSM, detailing assembly of CV (Birfield) joint: "Coat with molybdenum disulphide lithuium base grease before installing"
On page 6-16 of same manual, detailing final assembly of knuckle: "Pack molybdenum disulphide lithium based grease into the knuckle to about three fourths of the knuckle volume."
Good enough for me.
BTW - mixing types of grease (e.g. different for birf v. knuckle) is likely a very bad idea unless you know they are compatible. Incompatible greases can cause lubricant matrix breakdown, resulting in a watery mess and component failure."
In BOLD letters on pages 6-9 and 6-10 of the 1980 FSM, detailing assembly of CV (Birfield) joint: "Coat with molybdenum disulphide lithuium base grease before installing-crushr
ok so when i installed the birf i did coat with grease but i didnt "load" it up 3/4ths full. i was mainly concerned not having enouph grease behind the birf thinking that it could ruin something while driving. i guess ill just get a grease gun and fill er up. thanks everyone for the help. i just hope i put enouph in :cheers:
