- Thread starter
- #141
Come by the booth on Saturday and introduce yourself. Look forward to meeting my fellow mudders!Look forward to seeing you there![]()
Moving out of Cali is in my future. I'm a teacher so unfortunately I would make more at Walmart in most states than as a teacher!Those bare heads get expensive to outfit!
In the end that new 1fz will hold value
Could've done the ls swap and just get the Montana LLC... Or move out of Cali![]()
That's a shame! I never understood why they do that to teachers.Moving out of Cali is in my future. I'm a teacher so unfortunately I would make more at Walmart in most states than as a teacher!
Aftermarket HG . Toyota HG now have only small round hole- bottom pic- bottom passages at 6 or 1 -very end HG- Triangular holes at end of HG. those are the ones that would be round
It was definitely not cheap. I held on to the end, but was finally convinced to replace the cams. Glad I did. I spent the money (and more will be spent) knowing that there would be a certain amount of value retention in the effort. I did look into an LS swap, but only if I could get it CaIifornia CARB compliant. That proved to be a near impossibility so I went in this direction. definitely want to move out of Cali - i'm counting the time to retirement!Those bare heads get expensive to outfit!
Putting in a new fan and new fan clutch and new radiator - plus hoses! I figured if I am going to put $10k plus into a motor I better spend another $500 to ensure it stays cool.If you're not already, I'd def recommend getting a new fan at a minimum since it's out.
Good luck!
I did look into an LS swap, but only if I could get it California Carb compliant. That proved to be a near impossibility so I decided to go in this direction.Did you consider a V8 or any other type of swap? Mine he 308k, runs very well burns about a quart of oil in 5k miles but Iām always reading and thinking what I will eventually do some day. I also have a 1fz sitting on a stand that was rebuilt 19k before I rolled the rig it was in back in 2015. More horses would be nice at times but with an engine sitting here not sure I could justify a swap. Im a big diesel fan.
All that work and youāre not going to try to paint those rusty manifolds?
