Good brake pads
I am replacing the brake pads this week on the cruiser and was curious what brands you guys have had good success with. The PO put some pads on that dont work very well until they heat up. Any suggestions? Its a 93 with rotors fw and on the rears with abs.
OEM all the way, specifically the OEM pads produced for 97 rigs which apparently has advanced materials compared to the other OEM's. I've used the PBR 4WD pads and the PBR Ceramic pads along with my DBA rotors ( I think that PBR is another AUS aftermarket company that DBA recommends ) but honestly the OEM seems a better all around answer. One thing that I have also heard is good is Porterfield but I have not had them on the cruiser. HTH. :cheers:
100 Series pads minus the shim
Note: Only works with OEM rotors. Excellent pads though with 17% more surface area according to Dan. I'm only writing this though to point out to others that the OEM 100 series pads only work with OEM rotors. HTH. :cheers:
Why do they only work with OEM rotors?
Tripper
Tripper
Because the three aftermarket rotor manufacturers I've personally used or really researched (DBA, EBC and PowerSlot / PowerStop) are all making rotors that are around 32.5mm thick from the factory and the OEM is exactly 32mm IIRC. Due to the fact that the 100 Series pads already require removing the shim plate which is prolly .25mm at best, the non OEM rotors are just too thick to get 100 series pads in. HTH. :cheers:
Keep in mind that this is my trusty rusty micrometer talking here; IOW I did not try to pry my calipers open enough to install the 100 Series pads, I simply considered how tight the 100 Series pads already were with the stock rotors, found out from Dan that the stock rotors are exactly 32mm, measured my three different types of DBA rotors at 32.5mm proud and then really researched all the others that are listed above and found them all to be basically proud of 32mm by .5mm or so. If someone here has jammed some 100 Series pads over a DBA or EBC or PowerSlot I'd love to learn how it worked. Thanks.
Makes sense now! I was considering some straight up Brembo units from tirerack for my rotors. $57 a shot seemed pretty reasonable and their reputation is solid. Anyone run these? I'm assuming they fall into the 32+ category so I'd have to use 97 pads vs. 100 however not a huge issue on my end.
Here is a quick link for those interested and I don't mean to hijack the thread.
Brembo Replacement Rotor
I'm using the Brembo rotors with Hawk 100 series pads on the front of my 95.
Like was mentioned I had trouble installing the pads. If you do a search you'll see that people have removed some pad material with a grinder until they drop in. What I did instead was to lay some coarse sandpaper on a flat surface and rubbed the pad against the sandpaper in a figure 8 pattern until i removed enough material. The reason is I was concerned that I wouldn't be able to get the pad surface flat with a grinder. After installing the pads I did the recommended bedding procedure twice letting the brakes completely cool in between.
I was a bit skeptical about all of this but I had already bought the pads and removed the shims from them. I thought about buying a cheap set of 80 series pads and using them first but they say you should start with fresh rotors when going to 100 series pads. It really isn't a big deal though, the next time you replace the pads the rotors should be worn enough to allow the pads to drop in.
I have had zero problems out of this setup and the truck stops great.
OEM x3.14.......
I have DBA slotted rotors and run 100 series pads. So they do fit. I did leave the shim out, with no noticable change in the braking or noise. I was skeptical at first, but the 100 series pads do stop better and last longer.
So my math and my micrometer lied to me!!! Seriously did you do anything at all to make them fit other than take the shim out? I'd love to run the 100's but just thought that they would be dragging badly if they would force fit in in the first place. I don't like the idea of grinding away the material especially with a grinder which will produce variances in the flatness of the surface and which will also kick up dangerous dust and I don't really like the idea of sanding it either because sand beds into the surface of the pad and then scores the surface of the rotor. If I'm going to try the 100's I need to know that they "drop right in" but again my micrometer and my math suggest a super tight fit. Please edumacate me here! :cheers:
Edit: Here is a recent quote from a recent thread from someone else stating that they tried to fit the 100's but had to shim the caliper to make them work.
I had so much hassle going to the new rotors and 100 pads, I had to shim out the brake caliper to get the caliper to run central to the rotor, as there was no way the that one of the pads would go in.
I'd still love to learn what worked in your case. Thanks Again!
Turbo
No offense but don't you think you're being a bit overly anal here? The pads are metallic based, I seriously doubt that if any sand were imbedded into the pad it would score the rotor any more than the metallic substance in the pad! Even IF it did, pads and rotors wear. Any scoring, which would be very very small, would be gone in the first few stops.
Also, consider what happens when you go offroad! I live on the coast, there is deep powdery sand everywhere here and my rotors aren't all scored up! ;)
I appologize to the original poster for sidetracking the post.
As I said I'm using Hawk 100 series LTS pads up front and the HPS pads in the rear. I am extremely pleased with these pads. On initial cold braking they bite like a standard pad but as they heat up they start biting better. This is a much welcomed attribute when towing.
Probably what worked, was not knowing there was an issue!:D I had the rotors and just installed the pads. A tight fit, but really, no significant effort. I never realized it couldn't be done until I read this thread.
BTW-They were OEM 100 series pads from Toyota.
Good luck.
