Good brake pads
Turbo
No offense but don't you think you're being a bit overly anal here? The pads are metallic based, I seriously doubt that if any sand were imbedded into the pad it would score the rotor any more than the metallic substance in the pad! Even IF it did, pads and rotors wear. Any scoring, which would be very very small, would be gone in the first few stops.
Also, consider what happens when you go offroad! I live on the coast, there is deep powdery sand everywhere here and my rotors aren't all scored up! ;)
I appologize to the original poster for sidetracking the post.
As I said I'm using Hawk 100 series LTS pads up front and the HPS pads in the rear. I am extremely pleased with these pads. On initial cold braking they bite like a standard pad but as they heat up they start biting better. This is a much welcomed attribute when towing.
No offense taken and yes I'm always overly anal! :D Perhaps your Hawk pads are somewhat slimmer or perhaps minor machining variations between calipers means that some fit sorta tight without modification, some fit too tight without modification and some, like me, use math and micrometers to talk themselves outta it in the first place! You are probably absolutely correct that the sand in sandpaper is meaningless - I just don't like the thought of sanding brake pads I don't think that they use asbestos anymore but I just don't like the thought - did I mention I'm always overly anal? :D:D:D
Well I guess I have to be the cheap one here. On my 91 I run the Autozone duralast pads with the lifetime warranty. They wear out fast but replacements are free. I haven't noticed a significant difference in stopping distance vs OEM. I also like the Brembo rotors. They seem less likely to warp.
I ordered brembo rotors and hawk pads from tire rack today. Around $209 shipped which is pretty reasonable. Rotors were about 57 a piece, brakes were 60 something and 25 for shipping. I did get the 100 pads so we'll see how well they fit on my setup.
Tripper
I exchanged the original pads for the 97 pads and put them on today. It feels like a new truck. I have no idea what type of pads the previous ones were but they were junk. The 97 pads fit great and went on with ease.
I'm right in the middle of my first brake refresh/upgrade. So...
1) Brembo: All I can find is "front" or "front rear". Are the rotors the same spec front & rear?
2) 100 series OEM pads with no shim and Brembo (who says "machined to exact OEM specs") should be cool?
Thanks
Thanks
Aron, not trying to talk you out of anything cause I definitely don't know the particular Brembo rotors that you are looking at but just basically make SURE that the rotors you are getting are great quality; there seems to be a wider and wider range of quality in Brembo's various "sub-brands" these days. Not trying to offend anyone out there w/ Brembo's either by the way, it just seems that some are super while others are only average quality and selling the snot out of the name alone. Just really research it first but for argument's sake if you are going to get solid faced rotors (no holes, no slots) I really don't think that you can get ANYTHING better than OEM through Dan.
Another thing that matters to me (and admittedly prolly not to too many others) is that the rotors are matched all around the rig. In other words if these rotors that you are looking at are only fronts (no they are not the same spec front to rear on our rigs) and they don't do rear's in that same type rotor, I would not get them just for that reason. In other words, if I'm gonna go solid faced rotors (Brembo or OEM) I would get them all around, when I had the DBA Drilled & Slotteds those were all around and now that I'm sportin the DBA Slotteds they are all also around. Granted that this can quickly spin off into an argument about the fact that the rears contribute much less braking force than the fronts and that therefore "matching don't matter" but like I wrote already, it matters to me and if you're that type too I would only get a product from someone who sells the same type rotor for all four corners. Again, just one man's overly anal opinion! :D:D:D Hope that helps. :cheers:
Lots of parts searching, I suspect the OEM's were made by Brembo. (Can't say who they're sourced from now.)
Ultimately, I think I've decided to do OEM rotors all around with 100 series pads up front and SLEE SS lines.
There ya go, yer going to love that combination! :cheers::cheers::cheers:
How long until the pads go?
My brakes started making noise today. How long can I drive on these until I tear up my rotors? I understand there are a lot of variables but I drive in stop and go traffic about 20 miles a day. I can't get the work done until Saturday. I also need to buy enough time to get the parts shipped to me since I'll likely but the pads from Cruiser Dan. I also have no idea on the condition of the rotors. Any and all advice would be helpful. Will I make it until Saturday? Can I gets the parts in time?
Dude you gotta get a look with the wheels off; if it is just starting to make noise because the low pad indicator tab thingy (how's that for techiness? ) is JUST NOW starting to touch the rotor and there's still at least a millimeter or so of pad left you can definitely go until Sat as long as you are really easy on every braking. If however it is making noise because the pad material is gone and you are metal to metal, you should stop driving it immediately. Not to be rude any at all but NO one here can answer your question other than you because we can't see the shape of the pads. I hope this helps. :cheers:
Thanks, It is just the wear indicator. I'll pull the wheel off and look myself.
If it is just the wear indicators (all eight of them) and there is still some pad left like 1mm or more, you can go till this Sat to do the brake job. Make sure you scan over the inside and outside faces of the rotor because sometimes with sticking calipers your inside or outside pad will wear faster. HTH. :cheers:
