Getting the right shock
Roseville
I am about to order a set of RS9000's for my sprung over FJ40. I have 20" in the front and 19" in the rear from eye to eye, resting static and level. Does anyone know exactly what shock I should put on here for the maximum droop possible? I am a little concerned with some of the folks at the shop I am ordering from if they truely know what model Rancho shock needs to go on this. Is there a certain amount of shock rod that should be showing from the top of the shock at static? (3 / 4"???).
Anyone who is a shock guru and can help, please do!
Thanks.......Fman
I'm no guru, so...... This is just my thoughts on this. Up travel is just as important as droop.
So on that note I would say go 60 to 70% droop, and have 30 to 40% for up travel.
I'm running with a 25.5" pin to pin. 14.5" shock gives me 5.5"up and 9.5 droop.I can use that travel up in both directions.So if your at 20" I'd say use a 12" travel shock.
aw
probably search for shock threads theres a bunch out there
Hi All:
Wow Kurt! That is quite the "shocking" download! ;-)
Seriously, I noticed that no info on OME (Old Man Emu) shocks was included. If the "powers-that-be" would like to add some info in that area I have some to offer. "PM" me.
Regards,
Alan
Seattle
Static and level has almost nothing to do with getting shocks that will work.
The numbers you posted about your shock lengths are (I assume) based on stock mounts. If you want it all to work right, you can't use stock shock mounts in an SOA configuration. It will severly limit the length of shock you can run and therefore the amount of wheel travel you can achieve. Y'll crunch the shock on the upstroke and tear it in half on the doenstroke. I've seen more than a couple suffer this fate with stock shock mounts in SOA configuration.
Put new towers (longer/taller... Ford F250 towers work great) on the front. Relocate you upper pins on the rerar axle inward. Get four RS99012s (longest/most travel 9000 series shock) and run them on each corner.
I've done this in a BUNCH of rigs. Works gret, no complaints
Mark...
Josie'sLandCruiser said:
Hi All:
Seriously, I noticed that no info on OME (Old Man Emu) shocks was included. If the "powers-that-be" would like to add some info in that area I have some to offer. "PM" me....
Chat with Woody, I think he originally authored the chart... I have all the OME shock #'s too, I need to get them up on my site along with the leaf spring specs (I already have the coil ones done). :D
Do you work for/with ARB? Or just local?
