Gettin my locker!!!!
Golden, CO
Locker install prep questions.
:D
Just found out the AF is going to reimburse me for some travel that I thought was on my own dime.....hooray!!! I got money outside the budget to buy cruiser parts....and I thank the tax payers :grinpimp:
So I am going to pick up an Aussie for the rear and had a few questions. I've searched and read every thread as well as the install manual put out by the company. Couple things I could use to make it a good install.
I've never worked on my diff before so does anyone have a FSM they could make a copy of that section and mail it to me?? I'll paypal you postage :D
Also, does the year matter IOW for the thrust washers and axle seals does it matter or can I just ask Cdan to send me all the pats I need?
Casting numbers on the pumpkin to tell the year??
I'll replace, inspection cover gasket, axle seals, need the Hex drain plugs (mine are stripped) and thrust washers....anything I'm missing??? Besides gear oil :flipoff2:
Seems like it would be an easy install but again its unchartered territory for me and even though woody did the rear in an hour that means it could take me 12 + time for parts I loose or screw up :D
Let me know if this sounds right and then I'm off to call Cdan
Can't wait to get locked...then I'll only be one axle behind the wifes mall cruiser :princess:
man rear lockers rock my world, i got mine installed last weeken
but i don't know how to do it
i was a little hesitant at first doing my aussie locker, but let me tell you, its not as hard as you think its very self explainitory and if you have everything you need it will go by faster. i replaced the drain plug and gaskets. took about 2 hrs. im here if you got any questions you can call me too
I just put mine in a couple of weeks ago with no problems (rear s/f). I don't think you will have a problem, even without the factory manual. The instructions make more sense when you are actually doing it and can see how things fit together. One thing that you will need that is not on your list is some grease to help hold things together during assembly.
Good Luck
Thanks guys. I'll add grease to the list. Now what about the size of the thrust washers...is it one size fits all type thing?? Might be a good time to add the rock ring now available from troutindustries too.
i used the washers that where in there and had no prob. you need to make sure the gap isnt to wide if it is then you may need new thrust washers.
You might need longer studs if you go with the rock ring - and an extra hour and a torch to get some stubborn studs out of the housing.
My biggest struggle was getting the discs off the axles while fighting a caliper still attached by one pin because I welded my caliper mount in a bad position so the pin hits the leaf pack :doh:
It is pretty simple although I had to fight with the short side shaft to get it to re-seat after installing the c clip.
My Aussie instructions were sorta confusing for me to read, too much jumping around between axle types and stuff - too generic. Once you look at the parts and pics it is very straightforward.
Good luck
I saw a post somewhere abou the rock rings and I recall they were from trout but I can't find it here or on POR.
Am I going crazy?? Still waiting for woody's write up on it too.
DAn
Any other suggestions?
