Hey so I wanna run 315s or 35s do I need to gear down? I hav a 93 80s lc petrol auto now I hav read that on the petrol auto the gears are 4.6 or sumting and on the manual its 3.5 or sumting but yeh so do I realy need to get them done?
Thanks fellas well unless I can aford gearing I mite just get 33s (285s) thanks so now should I get a 4,5 or 6in lift I have a 3in on but is saging and I wanna go bigger especialy now wif da low bull bar.
The auto petrol in Aus usually has 4.11's, 4.56 ratio would return the overall gearing but to normal when running 35's.
I understood that 4.56's return the gearing to oem for 33's. 4.88 will return you back to oem for 35's. Sea level and no mountains , you might be ok with 4.11's and 35's, but you will be passed by every big rig on the highway at each hill. I just regard to 4.88's two weeks ago, much better!
Will it be drivable on stock gears and 35's? Yes.
Will it be slower getting up to speed and run at a lower RPM? Yes.
Will it crawl quicker? Yes.
Will it generate more heat in the transmission due to slipping? Yes.
Will you kill a bus full of nuns? No.
It all comes down to what you want your 80 to do. I say bolt them on and then decide if you need gears.
i live in colorado and have 315s with stock gears and it's fine. because of the lift, i wouldn't want it to be much faster in the mountains. i do have 4.88s on the shelf tho, because i want a little better crawl ratio
I agree but I heard the busload of nuns thing was a near certainty.![]()
