EDIT: @ 201whp, 3000rpm (35" Tyres), the AFR was actually 19.2:1
Boost curve included.
NOTE: this is on an inertia dyno, so bottom end boost response is significantly better than on the graph. And the AFRS show up richer than they really are down low due to transient nature of the dyno. It is very rich off the bottom however, this will be tuned out as much as possible in the coming week. I think we can get it to 16:1. I wasnt there for this unfortunately.
Red line is air fuel ratio, blue is boost in Bar. Even in transient, the boost is 1.45 Bar (21psi) by 1700rpm and 15psi by 1500rpm.
Hi Graeme.
Did you try to play a bit with the timing to see if you could get even lower better response?
I had this done on my ex kzj 73 and it made a world difference on my fuel consumption and low rev engine response 800 up to 1200/1300rpm over that it was as before but a bit more smooth running.
Might be interesting to give it a try if you have a chance when you are ont he dyno
Graeme,
Would you recommend using an oil catch can for when using your Turbo? Just curious what you think about the oil vapors being fed into the intake hose pre Turbo.
Thanks
i have not re installed my over the engine inter cooler it is my goal to do that this weekend, but honestly i almost want to keep it the way it is (if it is not broken don't fix it), i turn my manual booster adjustment to a maximum now i am getting 20PSI boost at 900 to 1000F and it wants to do more, i will have to get a new boost controller that will allow more boost. i hope you are all correct about the bottom end strength of this engine. i did not build Nulla to go that fast but it is good to know that power is there when you need it. i am just happy driving along at 65 mph.
i wonder how much difference my intercooler will make and maybe my fuel turn up 3 full turn.
Hello Amado,
20psi is about right and I'd leave it where it is. Unwinding the fuel screw will you the extra power you seek and refitting the intercooler will give more power on highway cruise - that is what I found.
Yes, your engine will always feel willing with this setup. I am astounded at the push in the back that I get at 110kmh/ 65mph and found myself easily hitting 130kmh+ when passing road trains a few weeks ago. Our open road speed limit is 110kmh, so I cannot take it out to maximum speed but I have no reason to believe it wouldn't pull to 4000 rpm in fifth gear given the way it feels at 3000rpm in fifth.
As a reminder to others, I've got a 12h-t with the first gturbo, 3" exhaust and a 600mm FMIC and removed fuel screw. Boost is 1.4 bar = about 20 psi
Tim
G'day,
Following on from my posting just above, I thought it would be useful to post the PDF I made up yesterday to show the revised routing of the pressure lines for the aneroid and the boost controller if you have fitted an intercooler along with a GTurbo.
You can see what I am about to describe if you open the attachment. If you can, open your PDF viewer with a sidebar so you can flick between the two images easily. Mac users can do this easily in the Preview app.
Okay, so what we know about the GTurbo is that it spools quickly. Nice isn't it!
Once you fit an intercooler, there is an amount of air contained in that intercooler that acts like a sponge and delays the full boost arriving at the combustion chamber, that's called lag. There is very little lag with a GTurbo setup, none that is noticeable.
What we want is for the injection pump, IP, to see that boost as quickly as possible so the rack opens up and supplies more fuel as early as possible. Your current setup probably has the pressure line that supplies the injection pump aneroid coming from after the intercooler. This can be improved.
The way to do this is to disconnect the pressure outlet on the GTurbo that currently runs into the bottom of your boost controller. Disconnect it from the boost controller and run it over the engine and connect it to the back of the aneroid at the back of the injection pump.
Now take the line was previously connected to the aneroid and run it across the engine and connect it to the bottom of the boost controller.
So, now you have achieved two things.
One is for the IP to see the high boost ASAP, adding to the punch in the back we feel.
Second, is that the boost controller now sees real intake manifold pressure and manages the waste gate according to that. Sure, it might raise boost momentarily AT THE TURBO slightly higher than you have preset on the boost controller, but that will not affect the turbo at all.
The result is a smooth application of power, a nice vroom noise and a big smile.
Tim
Tapage said:I don't see why not ..
