gturbo Upgrade Users Thread
I didn't see one so I thought I'd start a thread where users of Graeme's turbo upgrade can share their results.
Mine: Generally stock 12H-T in a US FJ-60. Stock injector pump with fuel screw backed out a few turns. Previous turbo had boost controller set to 14 PSI. Weight = 6200 lbs.
Before: Blew a little smoke on hard acceleration, but not bad. Typical slow LandCruiser. Pretty good torque. Much better than the 2F it originally had.
After: Significantly improved acceleration and torque. Boost starts as soon as I pull away from my driveway. Depending on gear and load I my boost gauge starts to move as low as 1400rpm. I see best low rpm boost in 3rd gear. Boost holds above 20psi until I reach my fuel limit at around 2800rpm. (I still have the gas fuel lines. They are a bit small for diesel and seem to be the limiting factor in performance for me.) My observations are purely subjective as I don't have before or after dyno data.
General observations: I found Graeme's turbo to be a good value compared to new replacements, and higher priced than a typical rebuild. For the most part mine was a pretty good "bolt-on". I had a couple of fitment issues. The exhaust manifold bolt pattern is off just enough that I had a pretty hard time fitting. I didn't have to drill out the holes, but it took some coersion to attach. The compressor outlet angle is slightly off making attachment to the cross-over pipe difficult. The turbine housing doesn't have a mounting boss for the existing turbo bracket, so I wasn't able to use it. I'll have to fab one so I don't have all that weight hanging on the exhaust manifold. The turbo sounds quite different than the original. That made me a little nervous at first, but I'm getting used to it.
Conclusions: Over-all, I'd say this product delivers on its promises. I need larger fuel lines to fully utilize it, but what I have seen so far is pretty satisfying. This turbo appears to be a nice upgrade without serious drawbacks. Time will tell what the long-term impact will be.
Would I recommend a gbentink turbo to a friend? Yes.
maybe i can get that with an other boost compensator slope.
