i as well have been battling the fuel pressure and boiling issues... since i've owned the cruiser 10 years ago. I've tried a few things, but recently what seems to have solved the issue is replacing the CC, replaced the Charcol , BUT I also drilled out the BB valve in the top lid. It was restricting the vacuum side. after removing that BB, i installed a vacuum gauge with a 1 way valve to keep vacuum going one direction on the small vacuum line (there's a "Y" right before the blue vacuum control with 4-5 lines to it.) Before the drilling, i was seeing pretty high vacuum 12-15, after, i was seeing about 4-5; which indicates it has more flow now, allowing the system to "vacuum out" fumes from the CC faster.
the vent line out the bottom of the CC is routed under the driver door area with a 1way valve and a filter on the end.
Also have a passive 24" fuel cooler, which didn't have any noticeable effect on the problem. I have a fuel temp / ethanol gauge, and monitored fuel temps and ethanol content when the issues occured. It was MUCH better with Ethanol free fuel, but still happened.
I have not had a pressurized tank or smell since! Super stoked! A/C, mountains, 100+ degrees, doesn't care anymore.
happy to share pics if anyone cares to see my "alternative" solution
don't judge, it works.
