gas mileage
Atascadero, CA
what is the average mileage for a fj-40 with a 350 (2 barrel carb) and four speed trans?
Well. this is my second look, I would say your milage will depend on what gearing you have, the roads you travel, how fast you like to go and how quick you like to get to said speed....That being said I get abour 12-15 MPG with a 327 3speed tranny and stock gears. The speedo only reads about 50MPH with 35" tires but with the GPS I am traveling 65ish...Oh and the RPM's are at about 2800-3000.
Good luck
mileagesucks
eaj71 said:
mileagesucks
yeah, it's best if you not think about, and just enjoy driving it(to the gas station).
FJ-40 Mileage
My 40 has a 350 Chevy with Edelbrock fuel injection and 4.11:1 differentials. The best I can get with SOA and 35" tires is about 14 mpg at 65 mph. Speedometer reads about 50 mph.
Don
Pleasanton, Ca
Not sure what I am getting but it is not too bad. If I were you I would put a 4 barrel on it you will gain a little bit more milage out of it because of the smaller primaries. That is if you keep your foot out of it.
i thought a four barrel would lower mileage by using more fuel. as far as kepping my foot out of it i dont know how likely that is. remember i am only 15. i dont have the slow and steady mindset
Well then drive it like hell to your girlfriend's house and forget thinking about gas mileage!
On a 4 barrel the primaries are smaller so it uses less fuel under normal driving but when you put your foo into it to hear it moan the secondaries open up then the carb become a controlled fuel leak on a intake manifold.
all right lat me get this straight. four barrel =better mileage with normal driving. four barrel = more power but worse mileage when i stomp on it. so would you guys suggest i go with a four barrel? im really not too worried about extra power seeing as i already have at least 100 HP over stock now, but i wont argue if thats the best way to go. what four barrels are the best for off road and mileage? thanks for all this info
IF IT WORKS, DO NOT **** WITH IT!!!
Put your energy into something else with the vehicle.
Good luck!
-Steve
FYI- The only reason that I would think of removing a working fuel delivery system would be to upgrade it to a fuel injection/throttle body set up.....but that is just me.
