@MuseChaser Oh yea, I ditched those lock bolts pretty early on, it was clear they were working against the whole operation.
Well, none of my small bolt holes line up now (I can’t even see the front or rears) so there’s no way mine would go in. I’m not sure the towers will slide once you’ve tightened up the two larger bolts, they’re pretty big. But I’m only carrying a canoe & wood....Ahhhhhhh HAAAAAAH!!! Yeah, they're the cause of all the difficulties, but I thought they were necessary to keep things from sliding around since everything else is slides/slots. Once you had your rack lined up and tightened all the large bolts, has it stayed completely in place without the small lock bolts when loaded up? We've got a heavy RTT (Tepui ruggedized Autana 3) that will spend a lot of time up there.
Pics coming..
Sorry for the late reply, just logged in and saw this. @Ayune advice is solid. My rack is moved forward 1 position than yours i.e. on the flat plates yours looks setup in the middle....mine is one bolt row aft which moves the rack forward 1-1.5". That helped me gain more front clearance as that's about the point where the roofline slopes down. I have the lightbar drop which would be very similar to yours. It's close, but no rubbing even with weight on the rack.
Re: Fore-aft adjustment... I have mine pretty far back I think because I'm loading a canoe on & off and I didn't want it to hit the hatch before it hit the rack.Thanks for the reply. My pics didn't show the middle towers; they're the ones preventing the rack from moving forward any further on my LX, as right now the towers are lined up with the aft-most slots on those middle plates of the rack, and everything's slid as far forward as I can. Those plates dictated where I had to bolt the front and rear towers to the rack. How did you get yours farther forward?
Took my first drive with it today, and rack itself looks great and is very, VERY solid. I need to fiddle with the bolt-on fairing a bit.. the clamps on the bottom don't grip the bar firmly and the fairing has a slight curve to it so the tips contact the bottom bar before the center does and it's making some noise. Any suggestions?
View attachment 1846031 View attachment 1846032
My Gamiviti should be here in a few days. I removed my factory roof rack. I used new bolts/neoprene washers to close up the holes while I wait for the rack to come in. Are neoprene washers enough to prevent water from leaking into the headliner? I want to wash/clay/wax the roof before. Also, I forgot to measure how high the stock rack was from the roof to the highest point of the rack (I have the normal 4 point B/D LX rack), does anyone have that measurement?
Even with neoprene washers, I'd still put RTV Silicone on all the bolts. That should button everything up nice and tight and prevent any chance of water intrusion. I don't know the measurements of the stock rack though.
