galvanizing a frame?
Cadillac, MI
Anyone galvanize their frame? If so were there any problems with warping of the frame. I'm planning a frame off resto in the near future and would like to protect my baby from rust. I was told powdercoating the frame would work great but I figured a hot dip would get into all the nooks and crannies but I don't really want to warp my frame either. Any thoughts or past experiences appreciated.
I have a couple Canadian friends who are gung ho Land Rover nuts and they refuse to restore without first galvanizing their frames or purchasing new galvanized frames. They are of course hesitant to admit any weaknesses of their Land Rovers to an FJ guy, but they do admit that LR frames have horrid rust issues. If you do an internet search on Land Rover Galvanize Frame, you'll get quite a few hits including ones from folks who have had it done.
From my understanding, the biggest negative is that once galvanized, any welding done to the frame is both dangerous due to the fumes and subsequntly destroys the galvanizing in the area exposed to the heat. Not sure how accurate that is having never welded a galvanized frame.
I did not galvanize a frame, but a friend here did it to his Corvette frame.
Two issues I heard him mention:
All threaded frame holes needed to be re-tapped.
There will be corrosion issues with nuts and bolts attached to the frame where the frame is galvanized and the nuts and bolts are not - sorry (wish I could but) I can't elaborate on this problem.
Good thing is they kill the rust, the dipping process it goes through before the galvanize takes it all off. I would think at that point a clean frame with a good epoxy primer and paint will probably last most of us a life time. Think about how long most of these frames lasted with a crappy factory paint on them.
singletrackjunkie - I was thinking to myself, reading your post, 'this'd only make sense if you lived in Michigan' - and I see that you do. I would not powdercoat a frame in a super wet climate like yours - when the rust starts underneath the powdercoating, it'll be much worse than if you had painted it.
I think you'd be fine with galvanizing, if you retapped all the holes afterward, and used anti-sieze on all bolts (which you should do anyway). Or, park the truck for the winter and drive an old K-car.
Hot dip galvanizing
I have had dock frames and bridges hot dip galvanized. The individual pieces were 16 feet long by 4' x 3' truss work welded up out of new hot rolled steel. The shop doing the galvanizing would not accept anything with paint or oil on it. It has to be clean steel. Mild surface rust will etch off. The piece to be dipped cannot have any dead ends that can't drain. The temperature of the zinc bath is 860 degrees F. It seems that is hot enough to potentially take the spring out of a frame. I have built a half a dozen trailers and painted the frames on all of them. After discovering hot dip galvanizing I would never paint another one. That said, I would probably paint the FJ frame and not risk leaving it soft. Hot dipping will leave some rough jagged edges where the zinc drains off. It might not end up as pretty as you'd think. It will weather to a dull mottled grey. Everything you want to do to the frame would need to be done first, no welding later. Threaded holes will clog as noted above. Yes, too much downside. I'd definitely paint it, shiny black & beautiful.
I had looked into it a little when doing my cj8. Seems like some places clean the frame for you, acid dip or something to make sure there is no rust, paint or oil on them, like you said it has to be very clean. I think jeep people do this a lot to their frames.
As mentioned above, if you weld on galvanize the fumes are toxic and it will destroy the properties that protect and rust right away in that area. I have welded trailer frames, School bleachers and other galvanized stuff and it welds okay but better if you grind it first. If you decided to paint it afterwards old school, the galvanize had to be washed in vinegar or meratic acid solution to neutralized it otherwise the paint would flake off with a little time. However a lot of todays paints adhere with little problem. Not sure about POR-15.
Maybe I shouldn't admit it on here, but I've owned a few series Land Rovers. Series Rover frames are paper thin from the factory, their strength comes from being fully boxed. Because of this the frames are notorious for rust-through and breakage and they're difficult to fix because you can't find enough good metal to weld to! I think this is why Land Rover guys go overboard and galvanize their frames.
Cruiser frames are much more substantial. I think paint or powdercoat looks better and the galvanized frames just don't look right under there.
OSHA says welding galvanized metal is safe even without a respirator. If you inhale a lot of the zinc oxide fumes you'll feel sick the next day, but it's not really dangerous apparently.
Galvanized frame
I guess it depends what you are building. If it is a restoration that you want to look somewhat stock I think the galvanized frame would look very out of place. As mentioned above, if the zinc is just to protect the frame and you plan to paint over it, it is very hard to get paint to hang onto zinc so it doesn't start flaking off. These frames are heavy & tough. With a coat of good primer & paint it will outlive all of us. If you are going for an industrial look that might look pretty cool.
I did it on my BJ42 frame off, probably the best thing I did and was relatively cheap at approx $.40 a pound. pain in the arse yes for you do have to retap all holes but as far as protecting your investment I beleive it was worth it. I even went overboard with it and sprayed rust bullet on top of that and then POR black chaiis on that. warping? I dont think so
R
Galvanic corrosion
... There will be corrosion issues with nuts and bolts attached to the frame where the frame is galvanized and the nuts and bolts are not - sorry (wish I could but) I can't elaborate on this problem.
It's called Galvanic or Dissimilar Metal corrosion LINK
One of my frames and cruisers was Ziebarted years ago, I dont know what they used but there is zero rust. If their still in business Id go that route and use good paints like PPG over the top. MIke
If I remember correctly several people here have galvanized their frames..and several like Roberto have coated on top of it..I know if you paint it you will need a special primer (etching?) or the paint will peel off quickly. If I had the facilities here to do it I promise you that's the way I would go....2 cents
Thanks for all the input. I haven't made up my mind yet but Crushers will be doing my resto later this year so I'm sure he'll start a thread for all to see. If I do galvanize I will plan on painting over so any exposed frame will be painted black. Roberto, I too would love to see pics of yours if you have them or a link if you did a thread, thanks
Brian
here pics before and after galvanizing. Link to my resto is called BJ42 resto
R
