Fzj80 getting hot.
Hey guys need some urgent help or advice.
I replaced all my gauge backgrounds last week.
Im only starting with this as i had to remove and replace my needles so they mightnt be in the exact original location.
This morning on the work on a pretty cold morning i noticed the temp gauge was getting a bit hot.
Wasnt anywhere near the danger zone but concerning never the less.
I dont want to cook it or blow a head gasket what steps should i take to make sure everythings ok.
Should i start by changing the thermostat?
I was doing mostly gm stuff for OBD 1 and with a good tool you could still pull basic live data.... ought be cheap to acquire but on the flip side hard to source. Either way you need accurate temp data before you start throwing parts at it.... like most things that mess up after recent surgery, the most likely cause is what you messed with
Thanks for the input.
Aparantly on my mid 94 fzj they have only the port on the firewall witch is basicly useless.
From my understanding other than a dealer you cant get anything to read the data.
You can take a look at #6 plug in less than 5 mins if you suspect HG.
Also this takes about 5 mins and can be rented at Autozone.
Install a koso gauge on the coolant output pipe, plenty of info here search "koso gauge mod". The stock gauge is useless
Always suspect when you didn't have an issue before you took it apart. I'd either try the above koso gauge or a IR temp gun. Also, there is a mod to the temp gauge that makes it much more responsive by just adding a couple of resistors.
Second the Koso guage, real time temps you can see go up and down according to tstat, rpm and rad flow/speed.
I wouldn't trust the stock guages they don't tell you it's hot until it's too hot.
On my '93 I have used a fairly inexpensive IR gun. I "shot" the coolant outlet pipe coming off the left front side of the head.
I caught my head gasket failure RIGHT as it happened because I had a koso gauge. This prevented more damage.
IR guns are great but you can't shot the outlet pipe when you are climbing a 10,000' mountain pass. That is when things get really hot.
As i need to do something asap as its my daily drivet im going to put in a new thermostat today to eliminate that as an issue and i also just got a full alloy 3 core replacement radiator that will arive monday i hope.
Aparantly it has 3 times the cooling efficiency of the standard radiator.
Im inclined to fit a new water pump at the same time.
Im hoping i havnt done a gead gasket but it hasnt got seriously hot jut hotter than usual.
Would it be worth replacing the fan clutch?
The other idea i thought about was removing the fan altogether and fitting 2 electric ones... anyone see an issue in doing this?
Doubt it does, OEM toyota radiators are beast. Replace the thermostat with a TOYOTA OEM Stat ONLY. (You could take the thermostat out and run it with just the gasket in there to see if that helps keep it cool.)
Unless it is making noises I wouldn't bother, Toyota water pumps rarely fail. If it is making noises replace with TOYOTA OEM ONLY.
Are you loosing coolant or oil? How do your plugs look? What color is your coolant?
Yes, I bought a new fan and AISIN clutch and it made a HUGE difference on mine. Electric fans do not hold a candle to the properly functioning mechanical fan (unless they are properly designed).
Do you have a fan shroud on and is it seated correctly? If not that is a problem.
Not worth it. You need a fan to draw air across the entire radiator core not just 12 or 14" diameter sections. To make electric fans work correctly you need a custom shroud built which is $$$. I have electric pushers on the front of my radiator and it only helps at rock crawling speeds.
Finally how do you know its hot? Is your stock gauge going to the red? If it is constantly you have more serious issues and I would start by removing your thermostat entirely (just keep the rubber O ring in there). Because your thermostat may be broken and not allowing coolant to flow. Also have you turned your heat on full blast when it gets hot?
Thanks for the reply.
I do have a fan shroud but i cut a small section out of the bottom of it about 4 years ago when i did my body lift with no notiable difference.
It hasnt got anywhere near the read but the gauge was climbing from half way where it usualy sits but running the heater definatly helped with this.
Im not losing coolant that i can tell and it looks fairly clean so without testing it properly im fairly confident that i havnt done a head gasket as of yet.
So you would only go oem for thermostat and fan clutch?
OEM thermostats are noticeably beefier than aftermarket. Infact Land Cruisers are very picky when it comes to parts, they DO NOT LIKE aftermarket cheapy parts. They literally chew them up and spit them out, you will save money in the long run by buying quality OEM parts up front.
Check with @beno or any of the other vendors here, they can usually get better prices than the local dealership.
I did buy an aftermarket AISIN fan clutch from Rock Auto, it's the same manufacturer as the OEM clutch.
Thanks smokingrocks
In in Australia so its probably easier and cheaper to source parts here.
Ill call the local toyota joint when they open and get some prices.
I plan on fitting the radiator and replacing all the coolant next week and with any luck that will sort my problem out.
Ive got aftermarket belts on and they slip and squeel when i start up so i should do them too.
I doudt they contribute to the problem but its hard to say
Picked up a fenuine thermostat and gasket today along with a new set of drive belts.
The viscous clutch for the fand is 548 bucks.... so i ended up ordering some genuine silicone oil off ebay instead.
How much fluid am i likly to loose if i drop the thermostat housing without draining the system first as until i get the radiator and a chance to do it i dont want to drain the antifreeze.
Ill replace it when the jobs done completlt
Was also looking for the fan clutch oil thread but ive only found page after page of reference to it.
Could someone please post the link...chèers dale
