FZJ Transfer case compatability
Kamiah ID
Does anyone know if the TC from a 94 will work in a 95?
Going to do the 10% underdrive high range gears and 3.11 low range gears in one fell swoop! I figured it would be more better to start with a complete rebuild and then swap them out as a unit. I like the idea of having a complete working spare if problems arise in the future!
I'm not sure but that is a OBD I to a OBD II ECU issue. Don or Kevin chime in will you? @ToyotaDon @Tools R Us
OK, I blew that one Eh?
Sorry.
So school me...
The 10% underdrive gears? Are those aftermarket or is that a stock gear ratio difference from 94 to 95?
Sorry.
So school me...
Aftermarket set by terrain tamer used aling with low range set to get lower low range and higher high range. Best of both worlds.
Transfer case re-gearing
Thanks for the reply's!
Yes the Terrain Tamer gear set from down under(AUS), Japan cut gear sets. They produce a overdirve and an underdrive high range set as well as a 3.11 Low range set.
Should be a fun project!
Thanks, sir!
Georg at Valley Hybrids is the expert/importer on this topic. If any of you have questions, shoot him a PM at @orangefj45
Wow, awesome they make 10% over & underdrives? I need to look into that...
.9 high and 3.1 low.... i believe under drive is closer to 25% percent low reduction and 10% over in high
Like Ward said.... contact Georg for more info
from Georg in the thread i linked
The low range gear set; usually 3.15:1 is a two gear set.
It includes the smaller gear on the idler shaft/cluster and the larger gear on the output shaft/cluster.
The high range OD or UD gear set replaces the input gear as well as the smaller gear on the output shaft/cluster.
We can provide TC gear sets that offer any combination of the following:
  • 1 to .9 in Hi (10% overdrive)
  • 1 to 1.1 in Hi (10% underdrive)
  • 1 to 2.65 in Lo
  • 1 to 3.1 in Lo
Georg @ Valley Hybrids & Cruiser Brothers
