Fuse boxes for projects?
San Diego
I just wanted to see if any of you do-it-youselfers would be interested in these fuse/relay boxes I have discovered. As you can see they would look pretty good mounted just about anywhere in your rig.
They have seperate wires to all of the connection points which you would have to crimp/solder onto. One has 4 relays while the other has 5 as well as another single fuseholder on the back side.
These would definately help someone to do a cleaner install than most of the stuff I see. They are factory Ford parts. Let me know if there is any interest. I have the 2 in the pic but could get more.
$25@ shipped should be fair, huh?
They're made to mount to a flat surface if it wasn't clear in the first pics
I like those; but more info would be nice. Size, type of fuses reqrd, overall specs, variety etc.
If there's something specific you'd like to know I'll try to answer it.
They hold 6 mini atc fuses with what appear to be 12 ga inputs and 18 ga outputs. If you're handy, you could probably move the pins around.
They each have 2 30A N.O. relays w/ 12 ga wires in and out
They also have 2-3 20A N.O, N.C relays but I think most of them are pinned out for N.C. operation
The fuse portion appears to be removable but doesn't have it's own mounting holes
Edit: Oh yeah, they're brand new, never used
Looks good but im covered already with a Blue Seas panel.
Yeah I've used those. They're really good quality. I figured these might be cool for someone wanting to wire an underhood or something. Relays and fuses for lighting and compressor,etc. all in one nice, clean package.
As with anything I offer up for sale, it's mostly just about seeing if anyone could use it as opposed to giving up my day job:cool:
I probably do need one but I just am horrible at electrical stuff. I know I will want to add a plug to the back cargo area and fog lights when I get a Sleet Short Bus later on. But I have no idea what I will need to do for that all to happen.
I'm definately interesed in both. One for inside and one for the enginebay. I live in Murrieta, is there anywhere to wheel around here other than wildomar? maybe we can meet and wheel and I can grab them off you instead of shiping them. I wanted to make the fathers day run but my rig is still running to hot to risk it.
You're not that far from Anza but it's a little too warm right now. we were down there a few weeks ago and it wasn't too bad. We all keep telling ourselves that this is the last run before summer but we still keep going out.
Sorry you couldn't make this run, we had fun.
If you want, I can try to get a couple more of these to put aside for you. Let me know
That'd be awesome if you could. Once my rig is running properly I could also come down your way to pick them up.
Thanks Alot
Kirk
