Fuse Block Question
Seattle, WA
Website
www.bladerunner80.com
I'm going to be installing my electric fan soon, so I thought this would be a good time to install a new fuse block as well. As time goes on, I'm going to want to install new electric items, and I want to do it right and not end up with a rats nest.
At some point, the PO installed a painless wiring kit with the fuse block mounted in the glove box. To increase my accessory capacity, i'm looking to purchase a Blue Sea fuse block (I can get them from West Marine out here in Seattle) . I wanted to mount it on the passenger side firewall in the engine compartment.
My question is, what is the best way to get power to this thing? I have two AMP meters currently installed, the factory meter and then an aftermarket one in a gauge cluster. I read somewhere on MUD if I don't correctly wire an accessory in, it will cause my AMP meter to read incorrectly. I would like to have the fuse box power hot all the time, so should I run a power cable directly from the alternator? Any tips on doing this the right way, please let me know.
Thanks!
You can connect it to the B+ lug of the alternator and the amp gauge will read correctly. It would be better to mount it in the engine compartment so that you have a short piece of unfused wire feeding it. This is a more modern wiring solution that minimizes the hazards.
If I wire it directly to the alt, then I'm gussing my accessories won't work in the engine is off. Can I wire it directly to the battery?
Hey man, check out Darren first he might have a better deal than the marine guys, for my application he did!
www.12voltguy.com
The B+ lug of the alternator is directly connected to the battery (through the amp meter on FJ40s) so it is always hot. A lot of people have discovered this inadvertently while wrenching on their cruisers. That is why it has a little rubber insulating hat over the connection.
One other important thing to consider:
The wire from the alternator to the amp meter to the battery has to be big enough to handle the total load from both fuse blocks.
The stock wire and meter isn't big enough.
Let me see if I got this right, by adding the new fuse block, I'm going to be adding components which will be drawing current through the entire system, and by having weak wiring running from the battery/alt to the ammeter and original fuse block I could be awkening sleeping electrical gremlins in my system? I'll go through there and beef it up. Thanks for the tips Pinhead, I really appreciate it.
hey BladeRunner80, if your interested i have several accessory fuse blocks (3 or 4 anyway) that are like new. they are from cop cars for all the accessories we put in them. when the city i work for upgrades stuff in the cars they buy all new parts and the old stuff gets tossed no matter how old or new it is :D so needless to say i have a few. if you want one (free) PM me and we will set something up. i am up around lake stevens granite falls area. i can also take a pic and send to you if you want.
that is exactly the set-up I have for my accessory fuse block
