Semi float WEIGHT and TORQUE on the axle = weaker unit. Full float no weight riding on the axle shaft it has a TORQUE load only and axle shaft is not necked down = stronger unit no hype.![]()
Hmmm! Why are semi floats 1/2 ton rated and full floats 1 ton rated? Semi float WEIGHT and TORQUE on the axle = weaker unit. Full float no weight riding on the axle shaft it has a TORQUE load only and axle shaft is not necked down = stronger unit no hype. Why do you think all 3/4 ton up to heavy duty trucks use a full floater design.
and not driving a FF with a locker engaged on hard ground will help...a lot..
it makes me laugh when someone says one of the reasons for a FF is to mount the tire easier...although true... if that is the case then getting back to the weight room is cheaper.
I'm surprised that I am the first to mention that another reason for
going to the FF on a cruiser is so you don't have to grind the ring gear
when installing a 5.29 gearset.
Food for thought for those of us needing LOW gears...![]()
