Fuel System Related Question
Clarksville, TN 37043
I have a 79 FJ40 with a mechanical fuel pump. If the cruiser sits for several days, the fuel evaporates or drains from the carb bowl and I cannot start the engine until I prime the carb.
Assuming I have a sound starter and fuel pump will cranking (not starting) the engine pump fuel and fill the carb bowl or does the engine have to be turning over much faster (running) before it will pump fuel and fill to bowl?
just turning the engine over with the starter will do the job,
you need to get the fuel draining issue remedied, it may be draining down into the intake.
I've had the starting issue since I purchased the cruiser but no amount of cranking seems to get fuel to the carb. or a least I can't see it through the sight glass.
I cranked the thing yesterday until the battery died and then connected a battery pack to it and cranked it some more. I never saw any gas through the sight glass.
If I prime the carb it will start and run fine. If I start it every day or two it will start without priming.
Any idea what the "remedy" to the draining issue is?
something is wrong. the stock pump will pull gas and send it to the carb with no issue.
disconnect the gas line going into the carb, run it or attach a hose to the end and run it into a container, see if any gas is being pumped out.
could be sucking air in any of the lines or the pickup tube
could be a bad pump
could be lots of things.
not pumping gas is a separate issue than the carb draining its gas.
When you do get it running after priming do you see fuel in the carb window?
To answer the last question first - once it starts I do see fuel in the carb window. When I can't see fuel in the window the cruiser will NOT start without priming. Once I get it started the engine runs well at all speeds.
I'm confident the lines aren't sucking air. The problem occurs regardless of the fuel level in the tank. I'm nearly finished with a frame off restoration and the same problem existed before the work began.
When I got the cruiser there was so much rust and crud in the gas tank that I could hardly start the engine without clogging up a fuel filter. One of the first things I did was to replace the gas tank.
The PO told me that one of the last things he did was to replace the fuel pump. I can't see any markings on it. My guess is that he put the cheapest aftermarket pump on it he could find.
Is it the consensus of the group that by cranking the engine a good fuel pump should be able to suck fuel out of the tank and into the carb at which point it should start even if the carb bowl was empty, to begin with? If yes, I think there is a new fuel pump in my future.
Was the carb rebuilt or at least cleaned after you replaced the cruded up tank (and lines)?
I had a rebuilt OEM carb installed on it, that I purchased from SOR, after the tank was replaced. I had the rebuilt carb installed on it because of the bowl draining/starting issue. The problem persisted even after the carb was replaced. This work was performed before I started the restoration.
When the cruiser arrived it had a transparent fuel filter on it and it had a lot of crud in it. I replaced the filter when I replaced the tank.
After running it a little I saw a bit more crud in the new fuel filter. I replaced it again. Since then I haven't seen any crud in the filter.
I cleaned or replaced all of the lines during the restoration.
Seems weird that the fuel pump provides enough fuel when running (assuming that includes running at high demand) but won't fill the empty fuel bowl when cranking a lot (till battery is dead).
Not sure on your weather conditions (heat/humidity); not sure of what type/formula of gas you get where you live but here in Ca. the gas (RFG) in my carb bowl can evaporate off in 2 - 3 days depending on weather. Stock fuel pump refills carb in a few seconds of cranking.
Like this here...
Hmmm, what condition would you experience if the bakelite ( did I spell that right..) spacer had been left out by the previous owner?
you experience a broken arm on the fuel pump and the pump does not work anymore.
it seems as tho the needle valve is sticking in the closed position thus not letting gas to re-fill the carb bowl, the OP could remove the fuel line at the carb and crank it over and see if gas comes out of the line. It doesn't make sence as to why after pouring gas in the intake it will run and fill the bowl.
So here is my update.
I installed a new OEM fuel pump 8 days ago and started it the next day. I went out this morning, after letting it sit for a week, and after cranking it for a few seconds the cruiser started right up. This was the first time since I purchased the cruiser that I have been able to start it after it sat for several days without priming it.
I'm hoping my priming days are over.
Thanks all for your comments.
