I understand man, I do definitely understand. I guess I've given Christo the benefit that he's saying the same things all along which include "it might lean things too much" and also that "it might not lean things too much". Keep in mind that without Christo working my wideband install, I wouldn't have had the courage to test the MAF any at all. It was he who told me the wideband had wisdom and that your mod might make my truck run like, what was it he said, "a raped ape" but to do this somewhat scientifically I shouldn't push the performance without the wideband and that I shouldn't rely on OBD-II data to determine things. He even openly offered me the use of his own scanner not to prove that your mod didn't work, but, to prove that it did!
I guess I'm simply saying that Christo totally helped me have the extremely enjoyable experience of your MAF and I guess I'm simply saying that he's acknowledged all along that running a little leaner will push the performance but too lean will push the risk. As I already wrote, I'm not emotionally attached; I totally get off on the scientific pursuit of performance so I'm simply not seeing this the way you would. You have put ten thousand percent more into this terrific mod than I have so please pardon my interference. I'm just saying that I absolutely KNOW your mod makes my rig run better in many many ways, but I'm also interested in identifying all the factors that affect performance and safety. I see this simply as another evolution of understanding, not as an attack, but again I acknowledge I'm emotionally removed enough to see things such way.
I admire the hell out of you and your mod. AFAIK, no one here other than yours truly has "pulled" 8.5psi through this thing transitioning from 6K ft altitude to 14K ft altitude at almost full throttle the whole way while watching wideband readings, scanner readings, temperature readings etc. I can say with complete certainty that this mod rocks but I'd also like to see the "Gen II" or "2.0" or whatever version take things to the next level. Ohh, BTW, whenever that is in the works, please place me as the first person to purchase!!! Your fond friend, Shaun.
