Well, I think that I came to this after-party "fashionably late"
. Christo you are welcome to post the logs if you would want although I remember you were wanting calculated load as one of the variables and I don't think that any of the logs I sent to you took load into consideration. I know I have some Stock MAF and LT MAF runs with those on them as well as with airflow on them. Might be better to find those first and post apples to apples.
Again, I want to emphasize that with the LT MAF the rig never read the 0's as with the Stock MAF; IOW I was never able to find the "saturation point" as I called it commonly even when it was reading 36.6 lbs air (off of my memory here so several grains of salt are recommended
) at 99% calculated load and over almost 5K rpms.
I also again want to emphasize that when we were running the stock MAF and saw the 0's we assumed that was open loop operation and it closely correlated with what was obviously open loop on my wideband. It wasn't until we swamped to the LT MAF that I realized I was in open loop on my wideband but the MAF was still reading strong.
Whether it is saturation of the Stock MAF or something else, one thing that is completely clear to me is that I couldn't find that point through LT's MAF. The calibration concern is a whole other worry and I cannot conclude anything on that without testing on some sophisticated equipment. Anyways again with the LT MAF there was no "saturation point" and there was no leaning past the point of 10.8 AFR at prolonged periods of WOT. That to me and to Rick was an amazing achievement considering that the Stock MAF the rig was reading 0's at around 60% load, getting stinkin rich and all the other things it definitely does do in terms of the shiftpoints etc.
All it took was one little look at the tests that you did (and thanks again for that truly) to see the relationship with the Fuel Pressure Regulator and boost and vacuum and the reference to Intake Manifold but as I've stated time and time again we still have many more questions to answer. Still, as you told me time and time again, the wideband has wisdom and so does scanner technology to a proper point and I can say with complete certainty that we never found the true "saturation point" or a truly troubling "lean point" with Ricks MAF. Is this the end of our equation, no clearly not, so, let's keep learning ... I love it all.
