Fuel line part #
Hillsborough, NC
i was changing my fuel filter and the fitting on the inlet side hose starting leaking after being moved around. Does anyone have the part number for that line? It's the soft line that goes between the metal fuel line and the filter under the hood. If you are a vendor, id be glad to order it from you. Thanks in advance!
Who's a vendor on the east coast?
Fred Anderson Toyota in Raleigh gives a nice parts discount to ONSC members. Ask for Phil Stetson. No shipping is nice, too. They keep a member list on file.
Is there something special about the soft line, or can you just use regular fuel line?
This hose?
Are you leaking at the banjo fitting? If so, did you do new washers on each side (or at least make sure both made it on)? I'd try new washers on banjo before I'd buy new hose. Walk into or call local dealership and see if they can help you. It will be a couple bucks and they most likely have them on hand.... Or are you leaking on end connecting to hardline?
It's the line with a banjo on one end that's crimped on and a brake line type fitting on the other end.
gotcha.....
I THINK it's 90923-01396
Though further south, @beno is on east coast, gives a 'mud discount, and is great to work with.
Thanks again guys! I got it ordered through Phil at Fred Anderson. That dealership is really close to work, so that's awesome!
Yep, he is an extremely valued resource, and a huge supporter of ONSC, but he has recently instituted a minimum order policy that this part wouldn't have met. I should have posted all of that in my response along with the mention of FAT for lesser items. Thanks for mentioning it, Bloc.
@84shortyota Beno will be at Logan's Run in September if you'd like to meet the legend. And 'wheel. And eat a pig.
Can you confirm the part number?
When I pick it up Tuesday I'll post it!
90923-01396
