Fuel filter I.d.
Peoria, IL
anyone recognize the brand/model of this fuel filter? Looking for a replacement element.
BTW If it were me, I'd run a longer hose to the carb and move the filter to the passenger side of the engine... that manifold gets VERY hot... you headers get even hotter - mine run at about 400*
Looks like a WIX, I use those or OEM
I don't know what I was thinking.......I use WIX and OEM but they look nothing like that, they both look the same and clip into the filter bracket on the 82 fj40, same as a fj60, must be a 81+ type
I also seem to have some of these metal filters laying around......must be for the 78? its the same part # as GA architect posted.
then there is the old style type that you can replace the element in, they come in glass and metal
FWIW: Toyota OME part 23030-60030 (09/1972 - 06/1978)....per this
Also, thinking about swapping the long hose w/the short hose and putting the short hose between the electric fuel pump and the filter, while the long hose would go between the filter and the carb. Any reason why the filter shouldn't be that close to the fuel pump?
What pngunme is trying to say is get both your fuel lines and filter to the other side of the engine, away from those headers. This is not the stock location, nor a good location. Maybe I'm just paranoid too.
Exactly... the driver side of the engine is considerably hotter than the passenger side. I don't like the idea of plastic fuel filter, glass fuel filter or anything like that, above the HOT manifold and/or headers.
@Landpimp and @GA Architect have shown you want the oem fuel filter looks like... if you are interested.
I have two new oem filters that I removed... I use the glass filter I showed earlier, with replaceable elements... I spend a lot of time way off road, with only my dogs and want to be able to see what the filter elements look like... so, I can easily swap in new elements when I deem it necessary.
To be oem, you need a hard line (5/16" steel or NiCop) from the fuel pump to the carb... this is safer than the rubber or silicone soft line over all that heat.
The fuel filter oem location is just downstream from the fuel pump (EDIT: I see you have an electric pump) e.g. before the fuel pump... to filter out any crap before it reaches the fuel pump... electric pump warranties are generally voided if you install it with no filter between the pump and the tank.
HTH
@SalmonMan , Hey Dennis,
23921 is bolted to the frame under the battery platform on mine:
Hi Brian,
Ok, nothing on the frame. Did locate a hole on the battery vertical support closest to the firewall that I think I can make work. Right now, just waiting for parts to get here. IF all goes well, should be operational by Friday. YEAH!!! :) Air cleaner came a week ago or so and came with a brand new air filter. Located the proper wing nuts for that as well as a stud for the carb to air cleaner. Basically, just ordered a metric stud and will cut it to size. Beats the price some wanted for a Toyota stud.
Then take it to my mechanic to replace the rear main seal. He said they will need to drop the tranny and suggested changing out the clutch plate while it was out. Makes perfect sense to me.
Once back home, add the new lights from City Racer, Bilstein shocks, and replace heater hoses. Only thing left after that is getting the license plate lights working. Do have a good electrical connection for those, but lights aren't working. One was burned out and the other appears ok. Will order replacement bulbs and then see what happens.
Oh, also take it down to the local tire shop and have them check the frontend alignment, since I replaced all of the tie rod ends. I think I have the alignment pretty close eyeballing it.
Later this winter, tackle some of the rust issues on the body and hood. Will save top for next winter, as will need help to remove that puppy.
Thanks,
Dennis
While they're in there they should also replace the pilot bearing and the throwout bearing, and maybe the clips on the release fork.
Check to make sure the clip that holds the clutch fork to the pivot is good and tight. This is the bane of clutches that won’t adjust properly.
Thanks! I've put my list together for things for my mechanic to check, based upon input from this site. I think while he's at it, might as well change the gear oil.
