Frustration Post, perhaps you can help?!
Hi All,
Thank you for this amazing community, I have been using this forum a lot.
This is a cry for help, I will try to keep this post short.
I bought a 97 FJ80 with 126 k miles 3 years ago, since then I gave it a lot of TLC (I don't have much mechanical skills) , I had the 3" lift done at mudrak (OME) and put on 35" tires , sliders, ironpig plate and ever since then , the ride has not been great, stiff, the rig is not very powerful although my mechanic said the engine runs like it is out of the plant (low miles:)) , breaking power is horrible to dangerous , the rig will not break at high speeds. I replaces pads as well as the rotors without much success there.
I really wanted to invest more, add bumpers and etc but I feel that I need someone to help me fix the above before I continue my investment, I think I already put around 8 K on this car...
I need a reliable shop that understands this problem or someone to help with the breaks as first priority and then see what are my other problems. people keep saying I need to put more weight on this setup but I kind of feel I need to believe before investing another 3-4 K on bumpers.
I live in the bay area, can someone recommend next steps? a reliable shop that will give good advice and fix the right things?
Let some NorCal guys reccomend a shop, pay to get the brakes bled (have you ever had the fluid swapped yet? Prob still '97 vintage fluid)
You can swap the 100 series pads, and even EBC 100 series pads if you want, Hawk makes some great pads too if new OE didn't impress you.
You can add a supercharger after that if you have $$$ for one -and if they are still available- that will help out.
There's a 5th step in bleeding 80 brakes that often goes unnoticed by shops - LSPV. Load Sensing Proportioning Valve. This can be a giant pain in the ass until it's figured out. It also needs to be physically adjusted after a lift.
Vehicle brakes are a system, not just a bunch of parts.
IMO, you ran before learning to walk here. You should have spent time/money/effort in vehicle maintenance rather than throwing a bunch of bolt-on items at it.
Personally, I always use OEM parts. I have been down the aftermarket road many times and always come home.
Your calipers probably need to be rebuilt at this point. Toyota sells caliper rebuild kits which are inexpensive but require time and effort. If you don't have the skills required, I would simply purchase OEM re-manufactured calipers for all 4 corners.
Did you replace the rotors on all 4 corners with OEM or aftermarket?
Your soft brake lines are likely 20 years old. Now would be a good time to replace them. Again, I use all OEM parts, but Toyota makes longer soft lines that add about 3" from a T100 for the axle drops. I don't buy into the SS braided brake lines that several folks sell.
By changing all of these components you will have effectively changed your old dark and dirty brake fluid as well. Remember, brake fluid is a clear liquid and it darkens as it becomes contaminated. IMO it should be changed every 2 years or so.
After you're done with new fluid, be certain to try to lock up the wheels on a soft surface to activate the ABS pump. You should do this several times as this will cycle the old, crusty fluid out of the ABS pump and back into the system. Then bleed the brake fluid again.
Make sure your vacuum/EGR/emissions system is fully functional as this could have a profound effect on brake performance.
As previously mentioned, after lifting a vehicle the LSPV must be adjusted to compensate.
@kobiav do you have any idea what lift or spring rates you are running ? It makes a huge difference in ride quality. For instance my truck rides like a brick wagon if I don't have the extra 600lbs of armor on it. The braking systems on these trucks are more than adequate to stop them even after lifts and tires. Your braking system is not up to par. You most likely have air in the system and old worn out fluid like was mentioned above.
thanks everyone!
Can Norcal members recommend someone other than Mudrak that is reliable for the job?
Willing to pay one of the IH8mud members to have a look at my rig and express their opinions, there's no one more expert on a fj80 than a fj80 owner...
thanks everyone!
Georg @ (@orangefj45 ) Valley Hybrids
Brakes on these rigs is a touchy subject. Some have great luck with all the oem equipment and others not so much. Such as the mysterious ABS pump issues. Start with the basics as listed above. Don't use cheap pads and rotors. Make sure to always "bed" in the new pads. Adjust LSVP according to your lift height.
For me I replaced everything possible in the brake system besides the booster. The only thing that finally made my 80 stop amazing was ditching the LSVP and ABS entirely. Until I did this they always felt a bit sketchy. That was after all new rotors, pads, calipers, lsvp, master cylinder, fluid replacement, and running about 3 gallons of fluid through the system.
I deleted the LSPV and the ABS on my '94 along with a new NAPA master cylinder, new Cardone brake booster, new NAPA calipers, new PowerSTop front rotors, new pads all around and bled and re-bled multiple times. My brakes are tight now, but it was an adventure. You are probably better off than I was when it came to the rust on your truck, but my LSPV was like something Mel Fisher might have found while diving for the Ascension. I haven't even bothered trying to get it off of there yet, I just did the cheap bypass method. My insurance actually went down when I told them I did this. I think the ABS and the LSPV are fighting you to some degree. I recommend just getting that stuff out of there and going with regular brakes. You can add a proportioning valve if you find the need, but I haven't yet.
Also bigger 35" tires and extra bolted on weight will increase the stopping distance. Adding more weight will only make the braking situation worse. 100 lbs is noticeable.
I wouldn't want mine to "break" at high speed ever..... so your good. Sorry, couldn't resist. Many beers in. Where in the bay area are you located? I'm very close to Gary. I adjusted my l lspv, new lines and fluid including "excercising" the abs many times with fluid flushing between and saw a huge improvement. Does it stop on a dime? No. I drive slow and plan ahead. Panic stops suck still. Larger tires and weight hurt that. New rotors, pads and calipers are in the future when I can make it happen.
Ditch the abs and lsvp.... I chased my tail for a couple years while dealing with iffy brakes. There was nothing else I could do to try and have good brakes. Everything was new in the system. Breaks sucked. Pulled in shop deleted that crap...pulled out of garage with some amazing brakes. Simple as that.
Second guessing my work I even brought to dealer and a couple indy shops. I believe the abs module is the culprit. It would almost make air in the system. So that's my .02 cents.
Did you regear the diff's? That'll make a difference in the power area.
If I lived in California I would take it to @orangefj45 aka Georg @ Valley Hybrids. Dude knows his stuff. Plus you know he's a no nonsense kind of guy because he doesn't even bother to use the wasteful e on the end of his name! :rimshot:
