Front Motor mounts
Swanzey NH
Both are busted, fan has shatered. Is there a better way? Is there an aftermarket mount that has a bolt straight thru?
Which mounts are you running? The round? The smaller rectangle?
Everything I do, I use the large FJ60 motor mounts, much larger than the original 40/55 mounts and tabs to prevent too much motor movement in the case of breakage.
http://www.cruiseroutfitters.com/engineparts.html
BTW, here is a pic:
So, your 60 series square mounts will fit on my 74-40?
My 76 FJ40 originally had the round mounts.
I ordered new motor mounbts from SOR a number of years ago.
I was suprised when I found that I got different motor mounts than what I had, but it became immediatly apparant that these new ones are a better desgin than the old round ones. and the fit without problems.
Anyhow.
Yup, they are slightly larger (~1/2" on all sides) but they fit fine assuming you don't have any weird headers, PS shaft issues, etc. I run them next to my 1" PS shaft... :D
Thanks for the help!
