Front locker not working
I have this same issue, except if I put my ear to the front locker, and have someone engage it, I can hear it groan. This tells me that a) the locker ECU is fine (and also the other lockers work too) and b) the front locker is getting power and moving. However, the light keeps flashing and I am (almost) certain that the front locker never engages - when doing S-turns on dirt, they never get noticeably harder.
Is the fork just not moving far enough?
I'd been battling that same issue for a couple of years before I ever got time to mess with it. As it turned out (for me, anyway) the position sensor inside the actuator was s***. When I realized that, I thought maybe it had been engaging all along. Of course, that would be too easy. As a result of the PO never cycling the lockers, the fork inside the diff was pretty seized up. With enough shifting crap around I was able to get it all freed up. This involved a lot of jacking up, cycling lockers, unplugging harnesses, turning tires, etc. Everyone always jumps to electrical malfunction, which isn't a bad thing. A lot of the time it is something electrical. But you'd be surprised how often something is just locked up.
Math,
You might be able to remove it and reinstall in the locked position. I had a similar problem when a new locker was installed unlocked by the dealer. I removed and installed per FSM, then all was perfect.
Izzy's amateur hour
And this was the procedure
Front factory locker issues
