Front locker not working
IL
My front locker light comes on but continues to flashes. The rear flashes and turns sold but the front just flashes. I noticed what looks like three or four wires broken. It looks like the go to the top of the diff. The harness does from the diff around the control arm and then up. The wires are broke right by the part that goes up from the control arm. Could these wires be what's causing the issues with the front locker? Do I just resolder the wires and wrap them? It looked like they were all black so I am not sure which one goes where.
Hopefully that made sense. I'll take a picture the next time I am under the 80.
If the wires go to the front diff locker, then they may be the culprit.
The center diff must be locked before the F and R lockers will engage and there is a sensor to tell whether it is locked, but since the rear locks it is probably OK. Stock wires are color coded with a stripe. If you have only 4 wires in the bundle, it is pretty safe to assume that the ones with the same color code were together.
I assume they go to the front locker but I am not positive. I don't know how many wires are there I just know 3 or 4 where broken. I will have to look again.
I hope someone can help.
I have the same issue on mine. Rear locker light is solid but front keeps blinking also.
What have you checked so far? I was working on my 02 sensor and noticed those wires. I was hoping from the description someone would know if those are the wire for the front locker.
Yes the harness on the passenger side connects under the cruise control, routes against the control arm before attaching the the actuator. II had mine damaged when the harness loosened up and wrapped around the front driveshaft.
That must be it then. Did you just solder the wires that broke?
Twenty years ago the replacement harness was $50. Mine was totally destroyed. It's stranded wires and could be fixed easily if just cut. You may have to add lengths of wire to extend the harness, solder and shrink wrap and use plenty of zip ties to secure.
Finished soldiering the wires. I had to clean up the wires. They were pretty greasy and you could not tell which wire was which. I didn't move the 80 much but did try for a minute or so and both lockers kept flashing. Cdl was engaged. I was pretty much sitting in one spot. I moved forward and back a couple of times maybe a foot or two and turned the wheel back and forth several times. I am not sure if didn't work because the wires weren't the only issue or if I needed to drive around a little more to engage them.
Sbrodacz, you really need to take it out to the dirt and drive it to see if it's working again. I had a problem with my front harness on my diff lock too, and as an FYI that harness has been discontinued by Toyota. I was able to find a Great local member (thanks Jackson) who sold me a used one for my truck. Anyway, if nothing else you can still get the harness ends from Toyota and make your own harness if your repair doesn't work. One thing i did find while working on my old harness is the wires that pass close to the exhaust pipe were cooked, the insulation just crumbled in my hand causing a short. so i took the time while installing the new harness to add extra heat insulation around those wires to make sure that didn't happen again. Another area that i found that had damage on my harness was were the wires go into the plug on top of the diff lock. I found i had two broken wires right were they went into the top of that plug.
Thanks. The wires weren't bad just broken. I was able to extend them and resolder them. I wrapped everything with electrical tape once I was done but I am going to a trail tomorrow. If everything works I'll had heat insulation around them (good idea).
Sbrodacz, First thing you might want to check is the diff lock harness to be sure you have continuity in each wire going to the actuator. If that checks out the Next thing you might want to try is removing the diff lock actuator from the axle housing. After you have removed it, check to see that the gear driven by the actuator inside the axle housing slides back and forth real easy. You see sometimes that gear gets gummed up if the actuator is not used often. Next get your service manual out and follow the instructions on how to test the actuator off the truck with a 9 volt battery, to make sure that it runs in both directions.
Thanks. I'll have to get a bolt meter and check the harness.
Sbrodacz, i see from your profile that your in the upper mid west, where there is lots of rust. Lets hope that this is something simple and not a case of water getting inside your actuator. Now if it is water and rust inside your actuator your still in luck. There is a real good thread here on mud on how to rebuild your actuator, but i have to say it looks like a real pain in the ass to do. Oh, and if i remember right, new front actuators are no longer available from Toyota, only the rear one's are, sad to say but the front and rear are not interchangeable.
Hopefully it doesn't need to be rebuilt. The truck has very little to no rust.
Get up in there by the actuator and have someone turn the switch while you listen for the actuator motor to run. If it runs, it may be a switch problem that indicates it is engaged. You can test if it is mechanically engaged by lifting a wheel and rotating it.
Is the light flashing And no locker engaging? In mine the light flashes but it engages perfectly. New sensor don't do anything either, so I leave it alone. You can test for engaged by lifting all 4 wheels and engaging.
