I just started getting a substantial vibration in the front end last week. There were several things I did that I am trying to narrow down. vibration starts at approx 35 to 40 mph and goes intermitently up to 65/70 mph. It increases on braking and cornering but doesnt always happen. the steering wheel shakes pretty badly.
1) rotated tires - new mtr's with approx 3000 miles on them - got them rebalanced with bead balancing compound and no change. thought they might have lost balance after chunks break off.
2) greased drive shaft..about 1 squeeze per zirk...pulled the front shaft and maybe slighly less vibration but it is still present.
3) added roof top tent...could addiditional weight cause problems? I am not thinking so because I have had it loaded up heavily before with no issues but it is a change.
I rebuilt the axles including new rotors and rcv axles just before christmas and have not retourqued the bearings. Will be perfoming the test tomorrow but is there anything else I should be looking at? Prior to this I have not had any wandering or other issues.
If the test shows loose bearings is it acceptable to just retourque or should I be tearing down the entire hub and repacking everything?
Thanks for the help
Thanks for the help
