front end clunk with video!!
Tigard Oregon
ive searched and read a few threads and it seems like the majority are saying front sway bar or bad shocks. How can you tell if you have a bad shock or shocks? Its a pretty loud clunk, obvious from the video and how far the video was shot from. And I cant always repeat it, like around my neighborhood going up and down over curbs. Ive looked and tightened all my suspension, im going to take off the swaybar for now and see if I can repeat it, after that its going to be going to the Kevin and John monkey show!!. (Tools R Us and Inkpot new business).
Heres a link to the video. http://www.youtube.com/watch?v=nL4EoFXKds4
Had a similar sound and had a broken/missing sway bar bolt on the front axle. Also could be a broken exhaust bracket so check the exhaust system too.
I had a similar noise. It wound up being the rubber bushing on the front sway bar. It was where the bar is connected to the frame (where drop brackets are added).
This is my first guess is worn lower control arm bushings. If they are original most likely they are worn out if they have been wheeled hard as they get older and dryer.
removed the front sway bar, (which has some bushings that will need replacing), but the clunk is still there.
You need to check every nut and bolt on the front end and put a wrench to them.
Inspect all of the bushings, tierods, shock bushings just because you think they are tight does not mean they are in good condition
Have your checked your wheel and trunion bearings for any slop lately
ive retorqued all suspension nuts and bolts, the wheel feels solid 9 and 3, and 12 and 6. My deal is that im not quite sure exactly what the bushings should look like. Whether they dont look too bad?, look alright?, or jeez, that is jacked!!!.
huh? Should they be greased or something?
If your running OEMs, then repack with Moly every 20 years. If you have replaced them already, I hope you spent the extra $$$ for the ceramic ones. They are supposed to be run dry, but I have heard of a few guys running dry lube on them. Good Luck. John
Also check the panhard rod mounting. A loose panhard rod will make that sound.
Did the bolt checking and bushing replacement maneuvers. Had a noise (more of a 'clank') in the front end that eluded detection until I got into the front wheel bearings - both spindles were worn, POs may not have set the preload correctly. Replaced the spindles, noise gone. I could not feel wheel movement with the 6 o’clock/12 o’clock wiggle test as the current preload was tight enough. Only 'clanked' on sharper objects such as sewer covers sticking up on a street that didn't have its final layer of asphalt yet, and holes and bumps off road. Didn't clank much at lower impact/speeds. Plus the noise from both sides made it difficult to pinpoint. Servicing the rear axle bearings now – spindles worn. :frown:
both front panhard bushings were just replaced by Camelback Toyota a few weeks ago, so thats not it.
Were the attaching bolts properly torqued? If one of them is loose it will knock.
I had the same sound after the first shakedown run once my build was done. (Maiden voyage was Rubithon......) I swore it was in the front end and it turned out being a loose rear sway bar drop bracket hitting the frame periodically while driving. It sounded like it was coming from under my feet in the front end. Might not be the culprit in your case but worth checking.
Hope this helps.
Crazy how many threads end like this... My problem is.... possible solutions suggested.... then nothing. Super helpful to everyone (like this post)
Just had a sound very similar to that, ended up being the shock bushing went bad.
lose control arms. tightened them up and the clunk went away.
