front drum!
wenatchee
ok so I just got done spending a little over 2 hours trying to get the front right drum off!! I took the hub off and the wheel bearing off, and I still couldnt get it off. I backed the brake pads all the way off. I dont know what gives the rear right drum came right off!
Have you tried hitting it with a hammer. I had the same problem with mine just a few well placed wacks and it came off. Might have to use a screwdrive to pry off if that doesn't work.
I was doing the same thing today! Had to pound the crap out of it with a hammer for a while. Used an old rug to pad it. Didn't take very long actually, but still had to hit it pretty damn hard. Found it best to hit in the 7/10/2/4 o'clock position.
Check for these two screws. Then like everyone else says whack the snot out of it with a BFH!
Hi All:
As usual, "Coolerman" is spot-on with his advice.
Like he said; make sure that the screws are removed, then go to town with the BFH on that drum! :D
I do hope this whole exercise is part of a front disc brake swap! :grinpimp:
Regards,
Alan
I think this is a useful tip especially when taking apart a drum brake axle where you are swapping in discs:
I found it very easy to one, make sure the above mentioned screws are removed or ground / chiseled off. I then unscrew the brake lines that go to the back of the backing plate. unbolt the bolts that are on the back of the backing plate (4 of them I think?) that hold the drum brake cylinders, one on each side of the back of the backing plate. Commense to hit them hard with a BFH. This I have found makes everything inside of the drum "fall apart" and then the drum will come off much easier as there is no longer any friction from the pads on the drum as it has been released becuase you have made the cylinders "free" and allowed the pads and everything to collapse inside the drum. HTH
Noah
Noah
That is a good idea. I'll file that one in my brain.
when i was young i worked for 2 days on 1 . finally burned a hole in it ran a chain through it and yanked it off with another truck not the smart way but it worked keep pounding and pulling good luck
Same Problem
It Is Strong, Mine Had Not Been Off In 5-7 Years. My Tec. Walked Up To It With A 5 Pound Hammer Hit It 4 Times, Bam... Right OfF, Went To The Next 3 Bam.... Same Damn Thing..... He Saw The Fear In My Eyes. He Said " Look At Them, Not A Dent" He Was Right........
ok well well I got it off! after another half hour and now i need a new drum ooops. what had happend was the was a nick in the drum and it had worn a grove in the brake pad and it got stuck there. I wish I was putting disc brakes on! thanks for all the help.
me? i got all the DB parts a waitin. after i effed with thise drums for 2 days a few years ago, i swore it would be the last time. surprizingly, the bastiges are lasting many a mile wo adjustments.
